Canal Digital DK, card | |
| Member Join Date: 20-07-2008 Location: DK
My System: DS7000/s |
Hi all, I have just received an DM7000/S and installed ”Gemini_0440” SW. My problem is, I can´t get my Canal Digital card to work (Paying customer :-), I'm not talking cardsharre or nothing. What have I missed, should I not just be able to plug in the card, and use “Common Interface”? Thanks for your help :-) | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | Try installing CCcam and set it as your default emu. Welcome to the forum | ||
| Regular Member Join Date: 29-02-2004 Location: Tyne and Wear
My System: 85cm transparent dish 0.2db lnb titanium wf100 cable dreambox500s technomate 9100 linux Eaglebox UK nds card | no, common interface is for you an physical cam. To use the card slot you need to have a softcam or emu installed, cccam will do it
__________________ Nice but Dim | ||
| | #5 | ||
| Super Moderator Join Date: 13-08-2007 Location: Middle East - Israel
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | If the CCcam doesn't help, as you have a CI slot in the 7000S as well as the card reader, you can try using a PCMCIA CI CAM (check first that it matches the encryption of the card that you have) and select Common Interface in this case. Edit: Checked the encryption for this package and it is Conax. See photo below Last edited by HB13DISH; 21-07-2008 at 08:16 AM Reason: Added Conax CAM picture | ||
