dream box edit question
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 17-10-2008   #1
My System: dreambox 500s
Hi guys been messing round with dreambox edit ie deleting channels renaming and re numbering is there any way to set it up so when you get your channel list up on your dreambox it is in numerical order rather than alpabetically
hope this makes sense
Mickie
mickie52000 is offline   Reply With Quote
Old 18-10-2008   #2
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
Make a custom bouquet and you can put them in any order that you like, but it will not automatically order them either by name or channel number.
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline   Reply With Quote
Old 18-10-2008   #3
compufunk's Avatar
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters
You can sort alphabetically by right clicking in the 'Details' pane within any bouquet. The numbering is based on the order within the bouquet as far as I remember.
compufunk is offline   Reply With Quote
Old 26-10-2008   #4
I am newbie for dreambox500s. I am deleting the channels pressing the following button of remote.
OK + menu then I select delete option. But channels are comming again.
How I arrange channels numerical order or my own setup, how to delete so that it will not come again.
I need this information through remote. I request the mod and exerts for guidelines through remote control.
PERVEZ is offline   Reply With Quote
Old 11-11-2008   #5
Thanks for no reply finally I have solved the problem through remote control, the procedure is put the desired channel in the bouquets from where we can arrange the channels. The qustion of the channels comming again not yet solved. Need help
Thansk
Old 11-11-2008   #6
mhku's Avatar
Is this in a bouquet or in the satellite channel list.
You can delete a channel from a bouquet and it won't reappear.
If you delete it from the satellite channel list I'm not sure if you can prevent it reappearing (I haven't tested it). You could try the "do not update service name" option - Expert Setup > Servicesname update
Old 03-12-2008   #7
Thank you for the reply. I am sorry it is late to answer. The problem is that some sex channels appeared on the same frequencies. I deleted all transpnders from satellite except few what is going on that on the same frequencies the sex channels coming again (not viewable especially for the kids who also watching satellite pressing ok buttons then selecting one satellite). Any way thanks I will try more to solve this problem if you have some more idea them let me know please
thanks
box, dream, edit, question
