Quick question ree Dream Box channels | |
| Member Join Date: 30-06-2008 Location: Newcastle
My System: Dream Machine 7020Si and 90cm fortec dish | When I'm looking at the channel list on the Dream box, I've came across to all the normal sky channels.. Is there a way to watch these ?? If so how do you do it ? I have a sky card, does this help ? | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | What image are you using? Install CCcam, set it as the default cam and put your sky card in the upper slot. You'll be able to watch the channels that your card allows. | ||
| | #7 | ||
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | CCcam Info. If you have a newer Gemini image you can download it usingBlue Button > addons | ||
| | #8 | |||
| Specialist Contributor Join Date: 16-03-2005 Location: Belgium
My System: Dreambox with PLi-Emerald 1.09 image, Matrix revolution CAS, newcamd emu, movable dish 0.85 m, very happy indeed | first make sure you can receive the free channels (BBC-ITV). That way we know your dish is correctly aligned & connected to your dreambox. Once that is the case, install CCcam & set as default emu (NO cardserver !), insert sky card (chip facing down) & reboot. this should open all the Sky channels you are paying for (and nothing more). | |||
| | #10 | |||
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | Where is it pointing? What channels do you get? Do you have a motor? You could have provided these details in your first post.
![]() 2. Move the dish until it points to 28.2. It helps to know where it's pointing now. | |||
| | #11 | ||
| Member Join Date: 23-01-2009 Location: bahrain,manama
My System: dm500 | lolz he is not getting any signal;try adjusting your dish to get proper signal do this menu>setup>service searching>sat find then u will be able to see signal respone and the lnb power adjsut accordingly and check whther there are 2 check marks in front of them | ||
| | #12 | |||
| Member Join Date: 12-01-2006 Location: UK
My System: Dreambox 7020 | Flippin heck, talk about bringing it back from the dead. You are right though, he isn't getting a signal. | |||
| box, channels, dream, question, quick, ree |
