28-11-2008
#2 |
| Super Moderator
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
| Are you using gotoxx or stored positions in motor config? |
You don't stop playing because you get old, you get old because you stop playing. Regras Before posting in the Dreambox section please ensure you've read The Guide Information is for educational purposes only  |
