Conflict - 1w and 28eDreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Specialist Contributor Join Date: 29-02-2004 Location: Tyne and Wear
My System: 85cm transparent dish 0.2db lnb titanium wf100 cable dreambox500s technomate 9100 linux Eaglebox UK nds card |
Everytime I install a new image or new channel lists there is always a problem with 1w and 28e, motor will not move. I belive that there is a problem with satellites.xml Anyone have a quick solution? Surly I am not alone | ||
| Nice but Dim | |||
| Regular Member Join Date: 28-03-2004
| hi m8, what image are u using? personally I never use sattelites.xml, I find that it delates some of my sats. I normally use satwizzard to install new images with all sttings from previous image, that way I know that all my setting will be the same. regards. | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | When you flash the image do you leave it pointing at 28E? If yes, go into the motor config and store the position as 28 Then do a "move to zero" (or words to that effect), find 1W and store the position as 1 Do a transponder scan for each satellite as well. | ||
| 28e, conflict |
