port forwarding the router to the Dreambox | |
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
Blog Entries: 4 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh |
I am having difficulties with conneting to the Dreambox The setup is as such: I got a DSL Router (FRITZ!Box SL) connected to the internet. The DSL router is connected to a wireless router (D-Link 524) by LAN. The Dreambox and the other computers in the network are all connected to the wireless router. 1) THe problem is I am not sure about the port forwarding. First problem, the DSL router gives you three optons for port forwarding, see screenshot. What shall I put in there various boxes?? I want to port forward 12000 2) If I port forward, does the wireless router also needs to be port forwarding the same? Thanks, TG | ||
![]() Last edited by T_G; 14-12-2008 at 11:37 PM. | |||
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II 1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs ![]() Saved us from the black plague of ignoratio elenchi, he awaits a special badge with jugs | | ||
Blog Entries: 4 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | I don't know what you are talking about | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Dont have any problems here,with my us robotnics router,to conect dreamboxes! what protocoll or cam do you use.for conecting to your dreambox? ccam/gbox etc? why,you dont conect,your db direkt,to your dsl modem router? | ||
| | #5 | ||
Blog Entries: 4 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | I use cccam I can't connect the dreambox directly to the DSL because I need to conect it to the network so the other computers can use the internet connection. I am pretty sure it will work, it is only the settings somewhere that need to be looked at.... | ||
| | #6 | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | You can find how to configure port forwarding for your router at portforward.com | ||
| | #7 | |||
| Specialist Contributor Join Date: 07-05-2008 Location: NW, Ireland
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | If its on the same network as the dreambox + dsl modem, there should be no need to forward any ports. I have a similar setup with a Linksys WRT54G. I didn't need to setup forwarding on the Linksys which is between the DSL modem and the Dreambox. I cant be sure about your modem, but I would try something like whats in the attached image. _http://portforward.com/english/routers/port_forwarding/FRITZ/SL-WLAN3030/default.htm I think CCcam uses a TCP connection, but I wanst sure when setting up, so I allowed both. If you want someone from the outside world to test the connection to inside your LAN, let me know. You can just forward port 80 to your dreambox as a test. | |||
| The Following User Says Thank You to compufunk For This Useful Post: | T_G (16-12-2008) |
| | #8 | ||
| Member Join Date: 23-11-2006 Location: uk
My System: dreambox 7020 | just a basic explanation of port forwarding: the outside world sees your network as a single ip address, the address of the router. on the other side of the router is your network where your computers can see each other and directly address/connect to each other to any port they wish. when an outside comp needs to connect to a specific computer in your network and to a specific port, that's when you need to configure port forwarding. say the routers external IP is 111.111.111.111 and your target comps network ip is 192.168.1.10. if an outside computer wants to telnet to your traget comp (and telnet default port is 23) then in your routers port forwarding you can set up: port:23 forwarding address:192.168.1.10 target port:23 you can just as well do port:any number (e.g. 777) forwarding address:192.168.1.10 target port:23 in which case the outside world would have to telnet to your target comp by explicitly naming the "777" port, eg "c:>\telnet 111.111.111.111 777" hope this helps | ||
| The Following User Says Thank You to vladimirx For This Useful Post: | T_G (16-12-2008) |
| | #9 | ||
Blog Entries: 4 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | Hi guys Tried everything. The computer does not port forwarding, I tried it through the web browser, and also I can see it from my friends cccam info, I am connected to him but he can't connect to me. | ||
| | #10 | ||
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | You might need to open that port on your firewall. I haven't figured out why, but sometimes I have to open a port in the firewall as well as forward it to a LAN IP address. Traffic is sometimes not allowed through unless I do both. | ||
| | #11 | ||
Blog Entries: 4 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | well, it seems I got it going. Done the port forwarding, but strangely to a different ip address than the dreambox. My dreambox has an ip 192.168.0.5, but the port forwarding is 192.168.178.20 . not sure why, maybe this is the wireless router IP??? Also what seemed to do the trick, I found a setting called DMZ on the wireless router, and when I put the ip of the dreambox (the correct one) it did work. Strange.... | ||
| | #12 | ||
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | DMZ= DeMilitarized Zone, Whatever is in the DMZ is left outside the security of your DSL modem / router. Its completely exposed to the rest of the internet. Its leaves the dreambox vulnerable to attack. Check it out, you should be able to telnet, ftp etc to the dreambox from the outside world when its in the DMZ Not sure what the heck is going on with your IP addresses. It wouldn't be the IP address of your wireless router because because the router would need to be on the same network (192.168.0.0) as everything else in order to work. | ||
| | #13 | |||
I found a way to turn the dmz off and still get the port forwarding: On the DSL router I port forward the 12000 and 16001 to the 192.168.178.20 (which must be the IP of the WIFI router). Then on the WIFI router I port forward the 12000 and 16001 to the Dreambox IP. See screenshots. If I turn off the port forwarding in either box it does not work anymore. | |||
| | #14 | ||
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | It seems you have two separate networks on the go (192.168.178.0 + 192.168.0.0) , and the wireless router is acting as a bridge between the networks, There is nothing wrong with that, But it would probably be more simple if you set the wireless router as an AP (access point). That way everything will be on the same network. That of your DSL modem. This would avoid having to forward any ports on the wireless router. Also if something goes wrong with connection(s), then you will only have one device to trouble shoot. | ||
| | #15 | ||
Blog Entries: 4 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | Hi Yes, it might be that. To be honest, I haven't got a clue about networks, and it is almost a miracle that I managed to set up the computers, dreambox, routers and all in such a way that they all work together. I reckon it is a combination of pure idiot luck and hours of stubborn trying that made it work ![]() I am waiting now for the new DSL WIFI thing to arrive, then hopefully it will all be easier. Thanks for your comments, I am sure a little bit wiser now about the networking side | ||
| | #16 | ||
| Member Join Date: 29-09-2009 Location: ksa
My System: nilesat 7w | I have speedtouch Thomson wireless multi user Adsl2+gateway router whcih one i bought newly but don't know how to configure port forwarding and dreambox IP. I have dreambox500s, any advise will be highly appreciated Thanks in advance | ||
| | #17 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Try portforward.com - its got loads of info on it | ||
| dreambox, forwarding, port, router |
