Usb
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 18-12-2008   #1
Usb
Thinking about buying a usb for my dm but don't know which would be good. Any recommendations?
k0103707 is offline   Reply With Quote
Old 18-12-2008   #2
Archived Member
Which dm model do you have?
HB13DISH is offline   Reply With Quote
Old 18-12-2008   #3
The 7020si. What usb would work best with this?
Old 18-12-2008   #4
Archived Member
If you mean USB flash stick, then a SanDisk Cruzer Micro works great.
I have tried both 1GB and 8GB in the 7000S and had no problem.
Even managed to record using Gemini 4.5.0 (has a new record menu).
But if you mean USB HDD, then I have to admit that I haven't used this possibility yet, as I am concerned about a PS oveload.
Old 18-12-2008   #5
Thank you very much for your help! Your're the best dude! hehe!
Old 19-12-2008   #6
Would this usb work?
_http://www.cclonline.com/product-info.asp?product_id=26401
Old 20-12-2008   #7
Archived Member
The price is too expensive.
SanDisk 8GB can give you 4 hours of recordings and you can take it out and copy the *.ts files directly to your PC's HDD.
If you haven't got a HDD installed, I suggest that you would have that in addition to the 8GB USB flash, instead of buying a 64GB USB flash.
Please update your location.
Last edited by HB13DISH; 20-12-2008 at 09:48 AM. Reason: Elaboration regarding the HDD
Old 20-12-2008   #8
Prince of Birthdays
dig deep's Avatar
My System: Dream7020 and AZ Elite
An usb-stick is a nice tool if You want to test or save some images without installing them all. Today most of the common brands are working very good so You can choose from the price and not from the brand.
I use a cheap 4MB stick and it works fine for me.
dig deep is offline   Reply With Quote
Old 20-12-2008   #9
I see! Thank you for your help guys as always!
usb
