SKY UK NDS - All channels work except Sky Sports/Movies
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 21-12-2008   #1
My System: MythTV, Skystar 2 DVB-S Card
Hi All,
This isn't strictly a Dreambox question - I use NewCS/open-sasc-ng (which used vdr-sc to decrypt) on Fedora with a Skystar 2 Card.
All the channels decrypt as expected except for the following:
Sky Sports 1/2/3
Sky Movies *
I have a legitimate Sky card with the Sports/Movies packages included. NewCS seems to pick up the card fine, finding two keys - one of type 0 and one of type 1. Channels such as Dave, Alibi, Sky One and MTV One decrypt fine.
I can't log onto the box now to paste the output from open-sasc-ng but, there aren't any errors. It finds the 0961 chain from NewCS but then says there's no valid key found.
Are Sports/Movies handled differently on the card to other channels? My kids/music packages work fine.
Any ideas? Thank you very much for your help,
splinterf is offline   Reply With Quote
Old 21-12-2008   #2
I'm still rattling my brains about this ... it's *so* close to working. NewCS seems to load the card fine - is it possible that NewCS can't see all the keys on the card?
Does anyone know whether Sky Movies are actually broadcast on channels other than those marked as Sky Movies? A bit like STREAM-* for BBC's Interactive Service.
Everything else works fine. sasc-ng simply complains that the keys aren't available from NewCS. They should be, because the same card decodes Movies/Sport on my Sky Digibox.
If anyone has a similar setup working or has any ideas please, please reply or PM me.
Thank you,
Old 22-12-2008   #3
Fixed: had the wrong boxid in newcs.xml - newcs can autodetect the right one.
Old 22-12-2008   #4
Amo Amas Amant Admin
Topper's Avatar
Well
Glad you managed to get it sorted by yourself, hopefully your posts will help others experiencing the same problem
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 31-12-2008   #5
My System: DM7025ST, DM7025SC, DM500, TT3200 S2 HTPC, Wavefrontier T90
I have same problem. What did you use for boxid parameter to get it work? Did you delete the parameter from config?
Thank you,
tequ69 is offline   Reply With Quote
Old 12-01-2009   #6
My System: DM 7020-S, DM 500-S - can't wait for my DM 8000.
Having trouble getting VDR-SC reading my NDS card. Does it need some sort of key?
Also, what's the story with the box id (which config file does it go into)??
pid0x11 is offline   Reply With Quote
Old 13-01-2009   #7
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
Guys , using the latest NewCS with the default config. You do not need to enter or change anything for the box id.
pid0x11, I've never heard of VDR-SC mate. If you're using a Dreambox anything other than a DM800 or DM8000 then you need to be using CCcam. If you're using a DM800 then you should use either NewCS with the card directly in the DM800, or use CCcam with the card in a Smargo smartreader+
Using either of these methods, you do not need a box id.
If you have a NDS3 card , be very carefull of the clock speed, do not exceed 3.57mhz or you'll cook it !
B16MCC is online now   Reply With Quote
Old 16-01-2009   #8
My System: I have a Dreambox DM500 connected with 2 LNB hotbird 13 and astra 19.2.
I have the same problem. i am using gbox 2.1b all channels working except sports and movies. can some one help me please? thanks you
noela is offline   Reply With Quote
Old 16-01-2009   #9
Site administrator
Analoguesat's Avatar
You are unlikley to get a reply - most of the members observe the authors request regarding not discussing gbox on public forums.
To be honest gbox is a flaky pile of rubbish which is well past its best - the newer cams are far superior, so think about switching to a better cam.
Analogue forever!
Analoguesat is online now   Reply With Quote
The Following 2 Users Say Thank You to Analoguesat For This Useful Post:
globopl (21-08-2009), sonic1 (16-01-2009)
Old 16-01-2009   #10
what do you suggest
Old 17-01-2009   #11
Prince of Birthdays
dig deep's Avatar
My System: Dream7020 and AZ Elite
Originally Posted by noela View Post
what do you suggest
Read post # 7
dig deep is offline   Reply With Quote
Old 18-08-2009   #12
My System: Wireless Net, Dreambox 500s
Same issue...
Hi, I'm experiencing the same issue. I have newcs166 and cccam211 (combined package) on Darkstar 2. All channels working fine except Movies and Sports. I'm using a New slyuk white card. Using standard newcs.xml with changes to:
<emm>10</emm>
<ecm>10</ecm>
And name and password. No other changes. cccam.cfg looks like this:
N: 127.0.0.1 10001 newcs newcs 01 02 03 04 05 06 07 08 09 10 11 12 13 14 1 4
N: 127.0.0.1 10000 newcs newcs 01 02 03 04 05 06 07 08 09 10 11 12 13 14 1 4
F: cccam cccam
And I'm sharing over cccam fine to another box in my house. But card still won't decode movies or sports channels. What am I missing?
Any help much appreciated, I'm new to this but learning fast. If you can just point me int he right direction. Have googled and gone through most available forums for last few days but can't see clear solution.
Thank you.
(Note: Have reflashed a few times to origional image with newcs and cccam, still no movies/sports.)
sharepapa is offline   Reply With Quote
Old 18-08-2009   #13
My System: 1.2 motorised with technomate
sharepappa - Have you checked your entitlements to see if they are updated? otherwise you will not get certain channels
Once you configure newcs to work with card then you worry about client (cccam) but first you make sure newcs read all your entitlements
cs91044 is offline   Reply With Quote
Old 18-08-2009   #14
andel's Avatar
My System: DM800 Panasonic 42" Plasma 1080p Pioneer VSX-LX70 Amp Sky HD B & W 5.1 Speaker Setup Popcornhour Media center Xbox 360
I'm no expert yet but in my experience you need to ensure you have the correct boxkey in Newcs. The boxkey is needed to clear the movies and sports only. I would start by checking that
andel is offline   Reply With Quote
Old 18-08-2009   #15
I got the boxkey by starting cccam manually (cccam -dv) and used this but it still isn't working. Should I use the serials from menu and box to get it (using B16Mcc's boxkey generator) or is this one read out by cccam correct? The card has already been paired with a sky box and Im told is working. (I don't have the box here though but can get it, i was doing this for a friend so it is in his house).
Thanks for your help
Old 18-08-2009   #16
Entitlements
Checked entitlements in contol panel and they seem fine also (date wise):
I don't know what these mean but I'm guessing from reading other posts that I must put my card back in the slybox before this date to get it updated.
| Provider | Expiry date | Expiry time |
| 0003 | 2009-10-11 | 00:00:00 |
| 000B | 2009-10-11 | 00:00:00 |
| 0010 | 2009-10-11 | 00:00:00 |
| 001D | 2009-10-11 | 00:00:00 |
| 30E1 | 2009-10-11 | 00:00:00 |
| 30E2 | 2009-10-11 | 00:00:00 |
| 30E3 | 2009-10-11 | 00:00:00 |
| 30E4 | 2009-10-11 | 00:00:00 |
| 30E5 | 2009-10-11 | 00:00:00 |
| B732 | 2009-10-11 | 00:00:00 |
| B736 | 2009-10-11 | 00:00:00 |
| B765 | 2009-10-11 | 00:00:00 |
| B766 | 2009-10-11 | 00:00:00 |
| B772 | 2009-10-11 | 00:00:00 |
| B773 | 2009-10-11 | 00:00:00 |
| B846 | 2009-10-11 | 00:00:00 |
| B860 | 2009-10-11 | 00:00:00 |
(Sorry for the double post, no edit obvious in here)
Old 18-08-2009   #17
And he tripple posts... I'll probably get banned for this but anyway. I got it working, just wanted to say thanks for your help guys. The problem was Cccam -dv was posting an incorrect Boxkey. Had my friend read serial from the bottom of the box the card was initialized in and put it into B16Mcc's generator. Put the hex into Newcs. Hope this helps someone else; main thing to remember: Cccam.211 -dv does not post correct Hex for boxkey. Thanks again.
Old 19-08-2009   #18
andel's Avatar
glad you sorted it
Old 20-08-2009   #19
My System: thanks
i have the same problem i have full sku uk all chanel work only de skysport.
can you help me thanks
globopl is offline   Reply With Quote
Old 20-08-2009   #20
My System: Dreambox 8000 Dreambox 800 Dreambox 500
how can I check newcs entitlemants I have newcs working with cccam, but dont know how to check entitlements...
shagx is offline   Reply With Quote
Old 21-08-2009   #21
B16MCC's Avatar
Use the web interface. _http://boxip:8080
There are 10 types of people in the world. Those who understand binary and those that don't.
Check Out My Blog :- Dreambox Utils For Windows
Best Regards, Your Friendly Dreambox Gimp.
B16MCC
channels, nds, sky, sports or movies, work
