YoutubeplayerE1_FinalDreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| DB Magician Join Date: 19-07-2003
![]() Merlin of the Idiot Guide |
YoutubePlayerE1_Final ################################################## IMPORTANT for dm7000 and dm7020 : Please use the attached YoutubeplayerE1_70x0. This version only works with vlc 0.8.6. ################################################## Works with both vlc 8.6 and vlc 9.8. Possible to select video from different Regions - GB, DE, IT, RU (Russia), PL and others. Possible to select Time-span for videos - from today, this_week, this_month and all_time. Possible to edit the vlc server-ip (with remote) or select from list. Install plugin :- The plugin will ask for libcurl.so.3 with some images and libcurl.so.2 with others. But the attached libcurl.so.2 will be ok - change the name to libcurl.so.3 (when asked for) and ftp to /usr/lib (for openembedded images) or /var/lib (for others) and chmod 755. The plugin .so and .cfg to /usr/lib/tuxbox/plugins (for openembedded) or /var/tuxbox/plugins (for others) and chmod 755 for the .so. The .xml file to /etc/tuxbox/config (for openembedded) or /var/tuxbox/config (for others). Edit to insert the pc-ip. Configure vlc 8.6 :- Settings - Preferences - Interface - Main interface - select HTTP. Settings - Preferences - Interface - Main interface - HTTP - Advanced options - insert in Host address :8080. Close and restart vlc. Configure vlc 9.8 :- Tools - Preferences - All (at the bottom) - then same steps as for vlc 8.6. Preferences - Stream output - select (tick) all boxes except 'display while streaming'. Open program folder VideoLAN (default install C:\Program Files\VideoLAN). In VideoLAN\VLC\http and \VideoLAN\VLC\http\old find two files .hosts. In these files find lines like : #192.168.0.0/16 Delete # and insert the pc-ip (vlc server-ip). Important to do this in the two files. Important when uninstalling another vlc version - also select option to delete preferences and cache. Tested with :- VLC media player version : 0.8.6a and 9.8.a Windows os : XP Pro Dreambox image : Gemini 4.60 Dreamboxes : 600pvr and 5620. (If it works with other setups - please post). Enjoy. ![]() Regards, pcd. | ||
| The Following User Says Thank You to PCD For This Useful Post: | kiko2004 (04-05-2009) |
| | #3 | |||
| Member Real name: lula Join Date: 28-07-2009 Location: croatia
My System: dm600 | hi PCD can u help me pls i have the same problem like
i try finale version and YoutubeplayerE1_70x0 but the same problem i have dreambox 600 and nemessis 4,4 image tnx for ur help and regards from croatia ps: sorry for my bad english | |||
| youtubeplayere1final |
