Originally Posted by B16MCC More from Me. This morning I ran my Sly IT NDS3 card in the smargo using CCcam 2.1.0. My card is a 0002 'K' type.
Early indications are very good. I ran the card very slowly using the following line in CCcam.cfg. Code: SMARTCARD CLOCK FREQUENCY : /dev/usb/tts/0 3430000
I have yet to monitor CCcam in debug mode via telnet but what I can see so far is good. From inserting the card into the smargo it cleared a channel within a couple of seconds. My local ECM time was steady at 0.175 , so thats good. The temperature of the card was quite normal with no excessive heat to worry about, absolutley no signs of burn, although the test so far has totalled only about 15 minutes.
This test was simply to run the card for my own local use. I will now expand the test to share it and perhaps increase clock speed slowly. I'll report back further findings. At this time I have no need nor interest in trying the card in the internal reader. I would recommend against it for the price of a smargo. |
Hi Bro
thanks for the info !
I just get my new
Sky Italy white k-type card and as I'm a bit afraid to burn the card i wants to confirm the settings first !
I have DM-800 with latest gemini 4.2 and smargo smartreader +and linux ubuntu server .
which combination is best option fo me and the card :
1- DM-800 and Smargo and CCcam 2.1.1 ( I dont like this setup as dm crashes from time to time )
2- Ubuntu server and Smargo and CCcam 2.1.1
3- whatever you say !
then its that the card is not active yet and i dont have the official receiver ! how do I activate the card !?
I read some where this process :
1- put dm on common interface
2- put dm on a sky channels
3- insert the card
4- telnet and run newcs
5- frm BP run CCcam 2.1.1
6- have a bear and wait
is this ok or i should I just put it in smargo with dm or ubuntu and wait !?
please any who has the experience help me set it up sooner !
thanks
