DM800, Gemini v4.1, CCcam v2.0.11 & S*y card in internal reader | | Hi,
I have a dm800 running gemini v4.1. I am attempting to use a UK S*y card in the internal card reader.
I installed these drivers:
dreambox-dvb-modules_2.6.12-5.1-brcmstb-dm800-20090310-r0_dm800.ipk
i downloaded CCcam v2.0.11 and edited the config to the following:
This is all I have in my config file:
WEBINFO USERNAME : *****
WEBINFO PASSWORD : *******
SERVER LISTEN PORT : 12000
SHOW EXTENEDED CLIENT INFO : no
WEBINFO LISTEN PORT : 16001
OSD USERNAME : *******
OSD PASSWORD : ********
SHOW TIMING : yes
SOFTKEY FILE : /var/keys/SoftCam.Key
AUTOROLL FILE : /var/keys/AutoRoll.Key
STATIC CW FILE : /var/keys/constant.cw
#CAID PRIO FILE : /var/etc/CCcam.prio
PROVIDERINFO FILE : /var/etc/CCcam.providers
CHANNELINFO FILE : /var/etc/CCcam.channelinfo
LOG WARNINGS : /tmp/warnings.txt
F: user1 pass1
C: 127.0.0.1 12000 user1 pass1
Now that doenst decode the card. No NDS encrypted channels clear.
Any idea on what I am doing wrong? Thanks.
Stvy |
