PVR and Playback functionalities | | Before my DreamBox 600, I used a Topfield 5000 PVR.
Clearly, the DreamBox is more fun, but what I miss from the Topfield are the PVR and playback functionalities.
While playing back, you can set bookmarks. With a button, you cycle through the bookmarks. This is useful when you stop viewing a TV show (for instance, because you want to play another recording), you can then return immediately to the point where you left.
It is also possible to cut parts of the recording, typically from the current point to the end, or from the beginning to the current point.
My questions:
1) Is there an image with these functionalities?
2) If there is not, would it be possible for me to implement this? Of course, I would need some guidance, but I was able to design extensions for the Topfield (TAPs), and I guess Dreambox should look more like a "normal" Linux box. |
