Originally Posted by cgworld Is this related to bandwidth or my wireless signal or something else? |
It's most likely is a bandwidth problem, I cant think of anything else that could cause it.
Depending on how your AP is configured you could be loosing bandwidth.
Under certain setups the bandwidth could be being halved.
E.g. A linksys wifi router configured as a 'client bridge' looses half of the available bandwidth going from 54Mbps to 27Mbps. This would be with a wireless G (802.11g) wifi network.
The above would probably be fine, but if its a wireless B (802.11b) you'd be halving your connection speed from 11mbps to 5.5mbps at best. The actual through put could be as little as half this again. So you can see why streaming would struggle.
I would check which wifi standard is being used by your neighbors wifi router. If its set to B, change it to G if possible (It may not be with older routers).
