Picons on Dreambox 8000Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Dreaming Satellites Join Date: 12-06-2005 Location: Stockton-on-Tees, Cleveland
My System: Dreambox 8000 HD, 80cm Orbital Satellite Dish Motorized LNB with 2 outputs, 2nd output leading to upstairs and using Dreambox 500S. Pioneer VSX-1018AH-K Amp/Receiver, |
Is this easy to do?? what do I need?? | ||
My System: Dreambox 8000 HD, 80cm Orbital Satellite Dish Motorized LNB with 2 outputs, 2nd output leading to upstairs and using Dreambox 500S. Pioneer VSX-1018AH-K Amp/Receiver, | Picons - The Channel/Provider Logos that you can have on the information bar for example; say you go to the MTV channel, the MTV logo will appear in the corner on the information bar | ||
| Specialist Contributor Join Date: 07-05-2008 Location: NW, Ireland
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | You just need to find the picons for the providers you want and copy them to the appropriate folder. Then enable the picons in the skin setup menu (If the skin supports it). Some images allow you to install them through the blue panel. Sorry I cant tell you exactly how to do it because I dont have an E2 box, so dont know the menu systems. It should be obvious where to put the files once you look at the skins settings menu, because you can choose from a list of defualt locations there. | ||
| | #5 | ||
| Regular Member Join Date: 04-07-2008 Location: Exmouth, Devon
My System: DreamBox 600s, Darkbox 2008, Liberty FTA reciever, Humax Foxsat HD, Thomson Sky+, 3 fixed dishes, 60cm for 13E + 19E, 80 cm motorised,Zone 1 sky+, BtVision and My 37" baby. | are they not called plicon? that is what they are call on my blue menu downloads, im running pli jade and you download them off the blue panel, | ||
| | #6 | |||
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | To be honest I wouldn't bother with them because its hard to get them for all channels, and when a picon is not available, a silly looking default logo is used which looks rubbish. | |||
| 8000, dreambox, picons |
