Originally Posted by td03-5 I find that bit torrent is particularly bad for this and when anyone on the LAN uses it the router is virtually unusable by anyone else! |
I've noticed the same thing.
The problem is that by default the torrent software opens far too many connections to other torrent users. Most typical cheap routers provided by ISPs are not up to having so many active connections and will throw a wobbly. This will make CS impossible and will cause general problems with LAN/Internet traffic.
The way around it is to go into preferences and severely limit the amount of connections the torrent software will try to make.
