dreambox dm600 pvr
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 30-04-2009   #1
sut
My System: sky plus box
dreambox dm600 pvr
hi
after several posts and alot of infomation i think i have decided to purchase the dreambox dm600 pvr i just have a couple of questions please.
im told i can record 1 channel and watch another on this box as long as they are on the same transponder. does this mean as long as they are coming from the same satellite? i.e to a newbie like me does this mean i could record sly1 while watching sly movies .
does the box come with a harddrive or do i buy it as an extra.
what should i expect to pay for this box.
and last but not least i have flashed an eagle box before
would this be the same guide i would use to flash the dm600 as not sure if its a different process for the 2 diffferent boxes or teh same.
once again thanks to all for any and all help
sut is offline   Reply With Quote
Old 01-05-2009   #2
Manic Midlander Moderator
nanochickin's Avatar
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription
Flashing is the same as the 500 if you use Dreamup but you can use the web interface which is a lot quicker
You can only record the same channel as you are watching on the DM600PVR.
The box doesn't come with a hard drive, you have to buy one and fit it. I got a 60gb HDD for mine off Ebay, Brand new for about £25
Expect to pay round the £210 mark for a genuine box to round £130 for a clone
Nano
Sanity is nothing more than an excuse to be boring
<<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>>
<<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>>
<<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>>
nanochickin is offline   Reply With Quote
Old 01-05-2009   #3
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
You can only watch another channel that's on the same transponder. This does NOT mean the same satellite. Each satellite has several transponders, each transponder carries a number of channels. Expect to see anywhere between 1 and 20 channels on any given transponder.
For example, Recording sly sports 1, you cannot watch Sky one, or movies. As they are on a different transponder.
There are 10 types of people in the world. Those who understand binary and those that don't.
Check Out My Blog :- Dreambox Utils For Windows
Best Regards, Your Friendly Dreambox Gimp.
B16MCC
B16MCC is offline   Reply With Quote
Old 02-05-2009   #4
You cannot record another channel at the same time on the 600, it doesn't work like that
If you try to change channel after recording has commenced, even one on the same transponder it will stop the recording before it changes channel after warning you of the fact.
If you decide to continue the recording it doesn't switch over
Nano
Old 02-05-2009   #5
compufunk's Avatar
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters
You can, I've seen the warning you are talking about. The way around it is to go to
Blue Panel -> Camd Setup -> All cams and enable the 'Can handle two services' option.
Its slightly different in the nabilosat images, I cant remember how to do it there, but it can be done.
At least you get to watch some other channels while recording.Its handy if there is something you want to watch on BBC1 and BBC2 at the same time.
compufunk is offline   Reply With Quote
The Following User Says Thank You to compufunk For This Useful Post:
HB13DISH (03-05-2009)
Old 02-05-2009   #6
I'll take your work for it
Not really a problem for me as i just record the other channel on one of my other boxes
Old 03-05-2009   #7
sut
how do you do this how does it work could i buy a dm 600 to record on to while i watch a channel from say an eagle box.
if this is correct how do you get the the stream running to 2 boxes.
i would love an explanation please. as i want to watch sly via these boxes and be able to record like i can on my sky plus box.
thx sut
Old 03-05-2009   #8
Archived Member
Thanks compufunk
I will try this later on with the 7000S.
HB13DISH is offline   Reply With Quote
Old 03-05-2009   #9
thx sut
Each of my boxes has its own independent connection to a quad lnb.
I also have a single dish on 30w so i can record something off TV Cabo while watching something off Sky on another receiver .
Nano
Old 03-05-2009   #10
Archived Member
Yes. It works.
With Dreambox 7000S and Gemini image
Blue Button > Camd Setup > all Camd's
Check the boxes of
- Can handle two services
- Multichannel mode
When you record one channel, press the bottom cursor on the remote and it will show you all the channels on the same transponders that can be selected.
The output is for the second channel, not the one that is being recorded, which can be useful in order to record it using a DVD recorder.
Old 05-05-2009   #11
My System: DB 500 & DB 600 pvr Motorised
Originally Posted by HB13DISH View Post
Yes. It works.
Check the boxes of
- Multichannel mode
hi i did all mentioned above but cannot make it work.
i have gemini version 4 on dm 600
when i try to see another channel while recording it tells me if i want to stop the recording, anyone can help me pls?
thks
rgds
cesco
cesco is offline   Reply With Quote
Old 05-05-2009   #12
Archived Member
thks
rgds
cesco
Which transponder are you trying to test?
Which CAM are you using?
Common Interface or emulation like CCcam?
Try with CCcam, then restart the box and see what happens.
Old 05-05-2009   #13
i am trying on it sly as i have sh... and the cam i am using is iw... its not common interface.
Old 05-05-2009   #14
Archived Member
I would suggest to try it on FTA channels first. It worked for me.
Old 05-05-2009   #15
hi managed on the fta but on the others no. do you know why pls?
Old 08-05-2009   #16
Archived Member
Yes. It works.
Check the boxes of
- Multichannel mode
Any idea if it is possible to do this without having to record a channel first with Dreambox?
The reason I am asking is that I usually record with an external DVR (not the internal HDD), but if I try to view another channel, the recorded channel will change.
Old 08-05-2009   #17
compufunk's Avatar
Not that I know of HB,
I've been wondering myself how I would go about watching a VLC stream on the PC while the missus watches whatever rubbish she wants on the Dreambox/TV (Same transponder of course).
dm600, dreambox, pvr
