Box Key ConverterDreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Dreambox Gimp & Coder Join Date: 16-11-2005 Location: /var/tuxbox/config
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | Dunno if this will prove to be of any use, but I just knocked it up in case it helps out. Enter the Serial of your sly box and it will give you a hex box key to enter into CCcam / NewCS . Please test it and let me know if its right. I'm at work and don't have a serial number to check. | ||
| There are 10 types of people in the world. Those who understand binary and those that don't. ----------------------------------------------- Check Out My Blog :- Dreambox Utils For Windows ![]() Best Regards, Your Friendly Dreambox Gimp. B16MCC ----------------------------------------------- | |||
| The Following User Says Thank You to B16MCC For This Useful Post: | sblinx (20-05-2009) |
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | Here's v1.1 guys. Change Log:-
| The Following 3 Users Say Thank You to B16MCC For This Useful Post: |
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | Ok guys, its been made public the method of converting the box key for the new white sly cards. Hence, I've made the appropriate changes to my Box Key Converter. This should now generate the correct box key for use with NewCS. It will display the line you need to enter into your newcs.xml so you can simply copy and paste it. Enjoy... | ||
| The Following 4 Users Say Thank You to B16MCC For This Useful Post: |
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | UPDATE:- It seems the sly box serial number doesn't always start 00, therefore I'll need to make a change to the Box Key Converter. Since the hex conversion is done by firstly removing the first 2 characters from the serial number, boxes that are not 00xxxxxxx will create an incorrect box key. Expect v1.3 tomorrow. | ||
| | #5 | ||
| Member Join Date: 11-11-2005 Location: Serbia
My System: Dreambox 500+; Echostar 770 (Strong 6155); 90cm Triax dish; Strong DM2100 diseqc motor. | You can try this little tool. The author claims it will work with sly uk, sly it and total tv. Then you can compare the resulting box keys and see if they match. _http://boxkey.110mb.com/ | ||
| | #6 | ||
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | UPDATE:- Version 1.3 Change Log. 1. Fixed bug where serial number doesn't start 00. 2. Cosmetic changes to GUI. 3. Generate box key from serial number in menu (11 Characters) or from sticker on bottom of box (17 Characters) | ||
| The Following 2 Users Say Thank You to B16MCC For This Useful Post: | CROSSBONES (26-05-2009), JTA (26-05-2009) |
| | #7 | ||
| Member Join Date: 20-03-2009 Location: na
My System: na | If I understand this correctly, the boxkey should be 8 characters. My hex converted serial is 8 characters long without a leading zero yet your program adds one making it 9 characters. Is this on purpose? | ||
| | #8 | ||
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | Ok mate thanks for pointing it out. Have you actually got the card working with your box key ? If so then please let me know and I will make a change and release v1.4. At the moment a leading zero is always added. | ||
| | #9 | ||
My System: na | Give me a few hours, my card is supposed to arrive today... UPDATE: it does work with the 8 character hex number, no leading zero. I didn't try adding 1 or 2 leading zeros. | ||
| | #10 | ||
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | Thanks for the update. Let me get this straight, you entered your box serial number and the converter gave you a 9 digit boxkey starting with a 0. You then entered this number without the leading zero and it worked ? Is that correct ? | ||
| | #11 | |||
My System: na | KH | |||
| | #12 | ||
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | ok mate thanks for the info. Expect version 1.4 later today which will only add a leading zero when the result is 7 characters. | ||
| | #13 | ||
UPDATE:- Box Key Converter v1.4.0 Fixed a bug for when the serial number converts to 8 digits, the leading zero is not inserted. | ||
| | #14 | ||
| Member Join Date: 13-04-2008 Location: UK
My System: Dreambox dm600 | Hello, Firstly, cracking little program - makes the job easier! I'm having a bit of trouble however, generating a Box Key using the Serial No. from an ancient Digibox (rumoured to have been used by Julius Caesar himself). The serial is 0003814858 (for some reason only 10 chars long) which, using your program, generates 03A35CA as the Box Key. I've tried entering this into my newcs.xml config but with no success - still cannot view Premium channels. Hopefully you can shine some light on the matter! ![]() Thanks in advance. Regards, Paul. | ||
| | #15 | ||
My System: Dreambox dm600 | Hello again, As a continuation to my message before, the 17 char serial number from the bottom of the box is as follows: 9F020A00038148586 This, in comparison to the serial number shown in the digibox menu, has an extra 6 added to the end. Needless to say however, despite using the converter, I am still getting the same Box Key. Any ideas? Cheers, Paul. | ||
| | #16 | ||
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | ok mate thanks for pointing it out. Have you tried taking the 7 digit box key and adding another 0 to it, to make it 00 3A 35 CA If not please try it and let me know. | ||
| | #17 | ||
My System: Dreambox dm600 | Hello, Thanks for your reply! I'm afraid yes I have tried that but still no joy. Just my luck to have a bloody awkard serial number haha! If you need any info I'll do my best to find it. Cheers, Paul. | ||
| | #18 | ||
| Specialist Contributor Join Date: 06-08-2004 Location: Down South
My System: Dreambox 7020si,SIF 1.9.4- Dreambox 800HD Nabilo BH 0.12 Netgear adsl router, 98cm Funkee on Diseqc motor, Maintaining Hummy 5400 for the old man! | You take the full 17 digit serial from the bottom of the box and use this tool you will have our box key Code: _http://boxkey.110mb.com/ Please let us know if it helps | ||
| | #19 | ||
My System: Dreambox dm600 | Thanks - though unfortunately I have already tried this site and it simply does not give an output. Strange! | ||
| | #20 | ||
My System: Dreambox 7020si,SIF 1.9.4- Dreambox 800HD Nabilo BH 0.12 Netgear adsl router, 98cm Funkee on Diseqc motor, Maintaining Hummy 5400 for the old man! | Have you tried getting the id from your old blue card ? Start CCcam with telnet followed by -d This should show you you box id. | ||
| | #21 | ||
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | Yep thats good thinking mate. sirsmilealot, as sonic1 says, login via telnet and run cccam './CCcam_2.1.1 -d' without the quotes. This will read the boxkey from your NDS2 card and show you it. Then do a hex to decimal conversion to see if you can make any sense of the serial number it gives you compared to the serial number you have on the bottom of your box. | ||
| | #22 | ||
| Member Join Date: 17-05-2009 Location: Earth
My System: DM 500 | I just obtained my Box Key from the menu. It's 10 digits long with one zero at the beginning. I've got the same problem as sirsmilealot. Is there a solution, please? Just had a look at theserial number at the bottom of my box: it's got 17 characters but the 2nd character is a letter. when using your tool I get "run-time error 242". | ||
| | #23 | ||
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | Ok thanks for letting me know, I'll look into it. Use the method mentioned. Insert your old blue card and start CCcam in debug mode via telnet. It will tell you your box key. | ||
| | #25 | ||
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | Use a temporary config with no F or C lines in it. And change the server listen port to stop attempted connections. | ||
| The Following User Says Thank You to B16MCC For This Useful Post: | drumcode (19-06-2009) |
| box, converter, key |
