Streaming HD Using VLC.
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 12-06-2009   #1
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
Thumbs down Streaming HD Using VLC.
Hi guys, simple question, has anyone been able to stream HD across the LAN using VLC ?
I'm using VLC v0.86i in MAC OSX and when I click to stream a HD channel from the DM8000 web interface it attempts to start then VLC crashes and shuts down. Any offers please guys ?
Cheers...
There are 10 types of people in the world. Those who understand binary and those that don't.
Check Out My Blog :- Dreambox Utils For Windows
Best Regards, Your Friendly Dreambox Gimp.
B16MCC
B16MCC is offline   Reply With Quote
Old 12-06-2009   #2
B16MCC's Avatar
Just tried VLC v0.9.9 and it streams locally ok. There is a little glitch every once in a while. Maybe a few per minute. I guess the bottle neck is the 100mbit nic in the DM8000. Versions directly following v0.86i had a problem streaming to web from a linux box, I'll test later to see if this has been resolved.
B16MCC
The Following User Says Thank You to B16MCC For This Useful Post:
Llew (12-06-2009)
Old 12-06-2009   #3
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
Yes, I have a problem with HD channels on v.086i. It opens in VLC and freezes on the first frame streamed. That's with Winxp. Doesn't crash, and audio carries on OK.
Might be worth trying the later VLC version, thanks.
Llew is offline   Reply With Quote
Old 12-06-2009   #4
Prince of Birthdays
dig deep's Avatar
My System: Dream7020 and AZ Elite
Tested my AZbox and it works fine.
Are You using a cable or wifi ?
As I use wifi I noticed a few freezing moments but not that it disturbs the view.
dig deep is offline   Reply With Quote
Old 12-06-2009   #5
Llew's Avatar
That's with LAN. There's a VLC 1.0.0 RC version available (beta I think) that might be worth trying. Might try it on my Linux distros, as the one currently available just gives an empty screen, no log file in Messages.
Old 1 Week Ago   #6
shumifan50's Avatar
My System: 2xDM7025(DVB-S tuner), DM600SPVR, DM800S, TM9100, Triax 90cm with MultiBracket 4 sats.
I am using 1.03. It plays SD channels fine, but it is virtually unwatchable on HD channels like SP HD. It seems to drop a LOT of frames giving a very jerky picture. I am using a LAN (no wifi), but it does go from the DM800 100MB/s LAN to a 1GB/s LAN on the PC. I am not sure whether this causes the problem. Is anybody else having the same problem?
shumifan50 is offline   Reply With Quote
Old 1 Week Ago   #7
WildBit's Avatar
My System: -DM800 fixed on 28.2-quad -DM7020 motorized -Skystar HD2 motorized -Cards&Cams&Cas
a few rare glitches, but nothing worth mentioning. I'm running Vista and streaming Sly1 HD right this second without any problems. VLC 1.0.3 running on the PC
shumifan50, Vista64, to be precise
WildBit is offline   Reply With Quote
The Following User Says Thank You to WildBit For This Useful Post:
shumifan50 (1 Week Ago)
streaming, vlc
