Multiple VLC stream
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 18-06-2009   #1
My System: dreambox
Multiple VLC stream
Hi all,
I read threads about VLC, but I didn't find the solution to my problem:
is it possibile to have more than one stream (in several PCs)?
For example PC1 see http://dreamboxip:31339/0,0450,0200,028a and PC2 http://dreamboxip:31339/0,0452,0202,028c
(Urls are the ones returned by clicking on the VLC link on the browser)
So far it works just with one PC.
Also, even using just one stream seems that it works just if the decoder is using the same bouquet ..
Oh, I have the 600 model with Enigma.. but i would like to know if it's possible in different configurations.
Thanks all.
bebo79 is offline   Reply With Quote
Old 18-06-2009   #2
Archived Member
If the URLs shown are real (not examples), I recommend to delete them for your own security.
HB13DISH is offline   Reply With Quote
Old 18-06-2009   #3
BombedOne's Avatar
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc.
is that UDP Unicast stream?
BombedOne is offline   Reply With Quote
Old 18-06-2009   #4
My System: dreambox
I have no idea, seems like it is?
Old 18-06-2009   #5
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
This would be specific to the box you're using. If you want the box to transmit 2 seperate stream simultaneously then it will need 2 tuners. If you have 2 tuners then yes it should work.
There are 10 types of people in the world. Those who understand binary and those that don't.
Check Out My Blog :- Dreambox Utils For Windows
Best Regards, Your Friendly Dreambox Gimp.
B16MCC
B16MCC is offline   Reply With Quote
Old 18-06-2009   #6
compufunk's Avatar
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters
Not possible with the DM600.
You might be able to get it to stream a different channel from the same transponder, but that's about it..
compufunk is offline   Reply With Quote
The Following User Says Thank You to compufunk For This Useful Post:
bebo79 (27-06-2009)
Old 27-06-2009   #7
My System: dreambox
Thanks,
do you know if is it possible with some decoders?
Old 27-06-2009   #8
compufunk's Avatar
A receiver with twin tuners should be able to do it (probably a linux box). I think the AB IP Box 9000 HD can do it but I've not tested this, I will when I get the damed thing back.
multiple, stream, vlc
