Originally Posted by HB13DISH Let us know if this helps.
I use Gemini and I never had any audio problems.
But perhaps you have your reasons for using what you have now.
What about FTA channels? |
It's been going for a few days now with no problems. Only thing I did notice was lip sync problems between the sound and pictures on some pay channels. FTA channels are fine. However when there was a loss of audio before it was a complete loss of audio for all channels, including FTA.
My reason for using Nabilosat is the EPG, plus I find it the best general all round platform.
Originally Posted by B16MCC Just one point from me. In the RF output settings I have to change frequency from 5.5 to 6Mhz . Otherwise I get no sound at all. Try this for your RF sound issues. |
How do I do this? In my RF Output menu on the DM7025 it only gives options for :
Modulator - on/off
Channel: select channel number
Finetune: finetune bar
There is nothing for frequency. Is this elsewhere or is there an application for it? Cheers
