newbie card share problem
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 23-06-2009   #1
My System: looking for new sat setup
Hi guys,
I've been reading up on cardsharing with my 2 500s dreamboxes in my house (local netword) and the new s*y white card.
I have managed to install NewCS 1.66 & CCcam and can get the server dreambox to clear channels etc using the boxkey etc. I'm obviously delighted at that as I thought that would be the hard bit.
However I can't get the second dreambox to connect to the server dreambox so that the channels will clear. I have installed latest CCcam on to the client box and though it was only a matter of adding an f line on the servr and a C line on the client.
I can connect to both boxes on my pc and the 2 ip addresses are 192.168.123.2 (server) 192.168.123.3 (client).
On the server CCcam.cfg I have 2 lines:
F: user1 pass1
N: 127.0.0.1 30010 cccam cccam 01 02 03 04 05 06 07 08 09 10 11 12 13 14
On the client CCcam.cfg I have C: 192.168.123.2 30010 user1 pass1. The only reason I use port 30010 is because I downloaded a newcs.xml file and that the port that they were using.
Any pointers would be appreciated as I'm a newbie and been at this for an hour or so with no luck.
I got a log from telnet and it shows this so not sure if it helps someone help me find out what my problem is...
/var/bin > CCcam.211 -dv
23:33:22.895 CCcam: ============================================================
23:33:22.897 CCcam: starting CCcam 2.1.1 compiled on Apr 30 2009@23:37:01
23:33:22.898 CCcam: ============================================================
23:33:22.899 CCcam: online using nodeId 550182745cd4228f
23:33:22.910 CCcam: dvb api1 detected
23:33:22.912 CCcam: DM56xx/500/600 detected
23:33:22.913 CCcam: create 2 cam device(s)
23:33:23.195 CCcam: *** card found(new type)
23:33:23.273 CCcam: ***: using boxkey xxxxxxxx
23:33:23.433 CCcam: card added to broker with caid 963
23:33:23.455 CCcam: added 156 keys from /var/keys/SoftCam.Key
23:33:23.456 CCcam: readKeyfile: cannot open /var/keys/AutoRoll.Key or not found
23:33:23.460 CCcam: added 9 keys from /var/keys/constant.cw
23:33:23.461 CCcam: parsed 0 entries from /var/etc/CCcam.prio
23:33:23.557 CCcam: added 842 provider names from /var/etc/CCcam.providers
23:33:30.759 CCcam: added 8372 channel names from /var/etc/CCcam.channelinfo
23:33:30.761 CCcam: server started on port 12000
23:33:30.767 CCcam: new tcp client from 127.0.0.1
23:33:30.773 CCcam: newcamd server 127.0.0.1:12000 user: cccam
23:33:30.775 CCcam: newcamd receive error -1
23:33:30.776 CCcam: deleting client 127.0.0.1, signature failed
23:33:30.780 CCcam: found *** caid: 0x960 ecmpid: 0x504 id: 0x0
23:33:30.781 CCcam: found *** caid: 0x961 ecmpid: 0x504 id: 0x0
23:33:30.781 CCcam: found *** caid: 0x963 ecmpid: 0x504 id: 0x0
23:33:30.782 CCcam: cam[0] set PMT for sid=d2f5
23:33:30.785 CCcam: start EMM
23:33:30.823 CCcam: local ecm -> card /dev/sci0 0x963(0x000) sid 0xd2f5
23:33:30.903 CCcam: local ecm <- card /dev/sci0 error
23:33:30.904 CCcam: cam[0] ecm odd nok caid:0x963 id:0x0 pid:0x504 Unknown
23:33:30.923 CCcam: local ecm -> card /dev/sci0 0x963(0x000) sid 0xd2f5
23:33:30.923 CCcam: local ecm <- card /dev/sci0 failure from cache
23:33:30.924 CCcam: cam[0] ecm odd nok caid:0x963 id:0x0 pid:0x504 Unknown
23:33:31.023 CCcam: local ecm -> card /dev/sci0 0x963(0x000) sid 0xd2f5
23:33:31.023 CCcam: local ecm <- card /dev/sci0 failure from cache
23:33:31.024 CCcam: cam[0] ecm odd nok caid:0x963 id:0x0 pid:0x504 Unknown
23:33:31.614 CCcam: EMM demux 1 set
23:33:31.615 CCcam: EMM: not interested in 0960:000000
23:33:31.615 CCcam: EMM: not interested in 0961:000000
23:33:31.616 CCcam: EMM: start filter on *** emmpid: 0xc0 caid: 0x963 id: 0x0
23:33:32.989 CCcam: new tcp client from 192.168.123.3
23:33:32.991 CCcam: user user2 login attempt from 192.168.123.3
23:33:32.993 CCcam: client user2@1a8b93e4a3d28a72, running CCcam 2.1.1
23:33:32.996 CCcam: 1 cards --> client 192.168.123.3(user2)
23:33:33.747 CCcam: local ecm -> card /dev/sci0 0x963(0x000) sid 0xd2f5
23:33:33.819 CCcam: local ecm <- card /dev/sci0 error
23:33:33.820 CCcam: client user2 ecm request for handler 0x64 0x963(0x0) sid 0xd
2f5 failed
Any ideas why there are errors and user2 cannot connect?
(btw I gave 3 F lines to play about with different client lines so I have user1,user2,user3 and also being playing with ports like 12000)
Cheers.
hotbaws11 is offline   Reply With Quote
Old 23-06-2009   #2
Manic Midlander Moderator
nanochickin's Avatar
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription
Can you post your newcs.xml file and cccam .cfg file, removing the obvious bits.
Its a bit difficult to diagnose the problem without seeing the lines
Sanity is nothing more than an excuse to be boring
<<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>>
<<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>>
<<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>>
nanochickin is offline   Reply With Quote
Old 23-06-2009   #3
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
CCcam
Well done for getting the NewCS working. All is fine with that.
Ok mate, it seems you're getting a little confused with the CCcam config.
Firstly, the F line you've added to your server box is incomplete. It should read:-
F: user1 pass1 2 0 0 { 0:0:2 }
Next, on the client CCcam.cfg your C line port address is wrong.
Your client CCcam is connecting to your server CCcam, not NewCS. The port number in NewCS is not required by your client box. Also, since you didn't define the server listen port in your server CCcam.cfg it will use the default port for incoming connections as you can see in your debug output.
Therfore your client C line should read :-
C: 192.168.123.2 12000 user1 pass1 no
Make these 2 simple changes and it should work just fine mate.
Remember, your client is not connecting to your NewCS, its connecting to your CCcam server.
There are 10 types of people in the world. Those who understand binary and those that don't.
Check Out My Blog :- Dreambox Utils For Windows
Best Regards, Your Friendly Dreambox Gimp.
B16MCC
B16MCC is offline   Reply With Quote
Old 10-08-2009   #4
My System: DM7020 - TRIAX 90 CM -
Hi There,
Did the solution works?
Best regards
Peter (the Netherlands)
aphexx is offline   Reply With Quote
Old 12-08-2009   #5
The fact the guy has never replied or been seen for over a week would probably say that yes it has solved the problem
Old 17-08-2009   #6
Sorry for not replying but I managed to get it fixed on my own. I can't remember what I done though. If you need I'll look at it when I get a chance an let you know. Basically I followed the information posted on various forms an finally got it working.
Speaking of which I might do some research my self to find out if the new cccam release means white sly cards can now be read directly without newcs.
Old 24-08-2009   #7
Hi hotbaws11,
Can you contact me on my email address?
See the details in my profile.
Best regards,
card, newbie, problem, share
