mount dreambox 500
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 10-07-2009   #1
My System: eagle linux reciever, card share
mount dreambox 500
Hi all,
i would like to mount a folder on my pc to my dreambox so that i can transfer a plugin onto the box. The folder i have created is on the root of my C drive named 'dreambox'. I have right clicked the file, properties and have enabled sharing. I made sure the share was working by accessing the folder over the network on another laptop. after confirming the things on the pc side were correct, i went onto the dreambox. went on menu > setup > expert setup > communication setup > press blue (for mounts).
In this screen i have inputted the following settings:
IP: 192.168.0.3
CIFS
Dir: dreambox
LocalDir: \
Options: rw,soft,udp,nolock
Extra: nolock,rsize=8192,wsize=8192
User: *****
Pass: ******
Automount is checked
I then save these settings and press green to start mounting. Then this error pops up:
"CIFS mount error already mounted"
when i press red for unmount, a message pops up saying, "CIFS unmount '/' OK!"
I am confused. What am i doing wrong?
dadon123 is offline   Reply With Quote
Old 10-07-2009   #2
My System: Dreambox 500+; Echostar 770 (Strong 6155); 90cm Triax dish; Strong DM2100 diseqc motor.
LocalDir: \
You should write here /hdd.
Don't pay any attention to the warning "CIFS mount error already mounted".
Try to record something and if you can, then your monut is OK.
Another way of checking is: If you can access your folder on PC by choosing /hdd on your dreambox, it is also OK.
kalehrl is offline   Reply With Quote
Old 10-07-2009   #3
i added /hdd on localdir and now when i try to mount it, comes back with FAILED.
"CIFS mount '192.168.0.3/dreambox /hdd' FAILED!"
Old 11-07-2009   #4
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
Have you had a look at: http://www.satellites.co.uk/satellit...95-post28.html
If you try the search facility there are quite a few old threads on mounting hard drives.
Does this exist on your Dreambox: 192.168.0.3/dreambox /hdd
Try changing
Dir: dreambox
to
Dir: hdd (might be media/hdd)
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline   Reply With Quote
Old 11-07-2009   #5
still no luck. The information that needs to be put into the mount options are as follows:
IP: (NFS, CIFS, SMBFS)
DIR:
LocalDir:
Options:
Extra:
USER:
PASS:
Automount: (check or uncheck)
I have just discovered that i am using an 'Eagle Linux Box', which is supposedly a Dreambox 500 clone. The firmware is, "DDdemon_by_Rockydevil"
Thanks for your help
P.S. Any ideas why i keep on getting picture freezes every 5 minutes or sometimes less? i have realligned my sky dish, checked the cables and my internet connection is fast (im on a CS)?
500, dreambox, mount
