CCcamInfoPHP Setup Guide.Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Specialist Contributor Join Date: 07-05-2008 Location: NW, Ireland
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters |
Here is a quick guide to setting up CCcamInfoPHP (By TOOGOODY) for gathering stats on your CCcam peers and your server. You'll need to have a HTTP server running on the machine you want to run CCcamInfoPHP on. I use Xampp from Apache Friends _http://www.apachefriends.org/en/xampp.html You can use any server you like, I use Xampp for other purpsoses so I'll stick with it. (PS Xampp also includes other servers including MySQL and FTP). Download and install the appropriate version of Xampp for Windows, Linux or whatever you're using. Download CCcamInfoPHP (attached) and extract the files. Copy the extracted 'CCcamInfoPHP' to the web root directory on your system. If you used Xampp, that would be C:\xampp\htdocs by default. Browse to C:\xampp\htdocs\CCcamInfoPHP and open config.php with your favourite editor. Uncomment and modify the appropriate lines to connect to your CCcam servers web port. E.g. If the webinfo port on your CCcam server is not password protected.... Code: $CCCamWebInfo[] = array("DreamBoxIPaddress","16001");
Code: $CCCamWebInfo[] = array("DreamBoxIPaddress","16001","username","password");
Start Xampp. In the Xampp control panel, click the button to start the Apache server. Your firewall software may prompt you asking whether or not to allow traffic on port 80, allow it. Now open a web browser and enter this url _http://localhost/CCcamInfoPHP/ Click the update button to get your stats. Thats it. ################################################## #Notes, ################################################## I wouldnt hit the update button too often. I'tIl send out queries to your peers boxes which some peers dont like. Some people block your share temporarily if they get too many of these bad requests. One update a day is enough as long as you dont keep restarting CCcam. CCcamInfoPHP is more of a tool for gathering stats on your peers over a longer time period, where as the CCcam webinfo will give you more of a live view of whats going on. | ||
| The Following User Says Thank You to compufunk For This Useful Post: | wannabee (26-07-2009) |
| Member Join Date: 11-11-2005 Location: Serbia
My System: Dreambox 500+; Echostar 770 (Strong 6155); 90cm Triax dish; Strong DM2100 diseqc motor. | The easiest way to setup cccaminfophp is to use version 0.9. You just put your dream ip address, user and pass and 16001 port, and off you go. | ||
| | #3 | |||
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | There are 3rd party versions which have been bundled with an installer and HTTP server which I take it you are referring to. | |||
| | #4 | |||
Maybe because it was the easiest. I tried other versions with no success. | |||
| cccaminfophp, guide, setup |
