Help with NewCS 1.67 and Card Sharing
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Closed Thread
Old 07-08-2009   #1
KalKal
Posts: n/a
I am currently trying to configure a server to run several cards for me and a few friends who have all purchased a card each but I am running into problems configuring the server. I have been doing this for a few weeks now and seem to be getting nowhere fast. I have a Linux based PC running Clark Connect with 1 serial pheonix interface and 4 Infinity USB Smart readers. The cards that I am using are a Sky Italia NDS3 card, a ITV Partner Cryptoworks card, a German Premiere card in Betacrypt, a Digitalb Conax card and a Viaccess card. Now the Viaccess and Conax card are running perfeclty well. The Premiere card is working but when the server is sending keys the picture freezes briefly and then its working again for several minutes before this happens again. The Sky Italia and Cryptoworks card do not want to seem to work no matter what I try. I am using NewCS 1.67 which reads all the cards.
If somebody can look through my .XML file and tell me where I am going wrong it would be appreciated.
<?xml version="1.0?>
<newCSconfig>
<readers name="Phoenix Card Readers on Server">
<!-- <device>
<name>Phoenix on S0 (S*Y Italia)</name>
<type>phoenix</type>
<mhz>368</mhz>
<node>/dev/ttyS0</node>
<parity>odd</parity>
<reset>normal</reset>
<export>Yes</export>
<enabled>Yes</enabled>
<blocksa>No</blocksa>
<blockua>No</blockua>
<blockga>No</blockga>
<blockC0>No</blockC0>
<boxkey>XXXXXXXX</boxkey>
<crypto-special>No</crypto-special>
<ipk>0000000000000000000000000000000000000000000 00 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000</ipk>
<ucpk>000000000000000000000000000000000000000000 00 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000</ucpk>
<PTShandshake>No</PTShandshake>
<carddetect>yes</carddetect>
<newcamd_port>15000</newcamd_port>
<autosid>yes</autosid>
<Seca-PPV>no</Seca-PPV>
<pincode>0000</pincode>
<priority>round</priority>
</device>
<!-- <device>
<name>Phoenix on USB0 (Crypto Works)</name>
<mhz>368</mhz>
<node>/dev/ttyUSB0</node>
<blockC0>Yes</blockC0>
<......-camkey>0000000000000000</......-camkey>
<......-camkey-data>000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000</......-camkey-data>
<carddetect>Yes</carddetect>
<newcamd_port>15010</newcamd_port>
<autosid>Yes</autosid>
</device>
<!-- <device>
<name>Phoenix on USB1 (Via-Access)</name>
<mhz>368</mhz>
<node>/dev/ttyUSB1</node>
<parity>even</parity>
<crypto-special>Yes</crypto-special>
<newcamd_port>15020</newcamd_port>
</device>
<device>
<name>Phoenix on USB2 (Premier)</name>
<mhz>600</mhz>
<node>/dev/ttyUSB2</node>
<!-- <parity>odd</parity> -->
<!-- <reset>inverse</reset> -->
<newcamd_port>15030</newcamd_port>
</device>
<!-- <device>
<name>Phoenix on USB3 (Conax)</name>
<mhz>368</mhz>
<node>/dev/ttyUSB3</node>
<newcamd_port>15040</newcamd_port>
</device>
</readers>
<radegastserver>
<enabled>no</enabled>
<port>10001</port>
<allow>ALL
<!-- <hostname>localhost</hostname> -->
</allow>
</radegastserver>
<cache>
<!-- <emm>20</emm>
<ecm>-1</ecm>
<emm>10</emm>
<ecm>10</ecm>
</cache>
<httpd>
<server>
<port>8080</port>
<enabled>yes</enabled>
</server>
<user>
<name>newcs</name>
<password>newcs</password>
<accesslevel>admin</accesslevel>
</user>
</httpd>
<debug>
<password>NewCSpwd</password>
<mode>simple</mode>
<level>internal</level>
<type>all</type>
<output>console,tcp</output>
<tcp_port>1001</tcp_port>
<tcp_options>normal,init</tcp_options>
</debug>
<newcamdserver>
<name>newcs</name>
<deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
<userfile>/tmp/users.txt</userfile>
<user>
<name>user1</name>
<password>user1</password>
<au>on</au>
<spider>off</spider>
<sidoverride>off</sidoverride>
<rate>0</rate>
</user>
<user>
<name>box1</name>
<password>box1</password>
<hostname></hostname>
<port></port>
<au>yes</au>
<rate>0</rate>
</user>
</newcamdserver>
</newCSconfig>
I also have the output file for the Premiere card located here for download if anyone would like to have a look at it.
_hxxp://www.megafileupload.com/en/file/124626/NewCS-zip.html
If anyone can help it would be greatly appreciated.
Thanks in advance
Liam
Adminboxkey blanked for your protection
Old 08-08-2009   #2
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
Ok, for the Premiere card that is causing freezes, try settings the EMM blockers to YES, all 4 of them. If this stops the freezing then make each one NO again until you find out which one is causing the freezing. If the card is being flooded with emm's this may be the problem.
As for the Sly IT, I'm just setting one up myself for the pub on ubuntu, I'll let you know how I go on.
There are 10 types of people in the world. Those who understand binary and those that don't.
Check Out My Blog :- Dreambox Utils For Windows
Best Regards, Your Friendly Dreambox Gimp.
B16MCC
B16MCC is offline
Old 01-09-2009   #3
My System: Hotbird Sat 13E P4 3.2MGhz
Hey there!
So how did it go with Sky Italia? Did you get it working?
tank30 is offline
Old 01-09-2009   #4
B16MCC's Avatar
Yep, Sly IT is working great in an omnikey reader using NewCS 1.67 in ubuntu.
B16MCC
B16MCC is offline
Old 01-09-2009   #5
Would you mind sending me newcs config, reader config and software used in linux and website with exact reader model?
send the in PM if you mind posting them here.
thanks!
tank30 is offline
Old 01-09-2009   #6
B16MCC's Avatar
Its all here if you look around mate. Check out this thread, this is exactly how I do it.
How To Setup A Linux PC Card Server
B16MCC
B16MCC is offline
Old 01-09-2009   #7
Thanks mate,
i know how to setup server, i was just looking for a specific setup which actually worked with sly italia so i dont burn the card. Now that i know that omnikey 3121 is safe to use , i know what to order. The card is not so easy and cheap to find!
cheers!!!!!
tank30 is offline
Old 16-09-2009   #8
Help..anyone... its supposed to be working with omnikey but its not! Anyone of you guys with the omnikey reader working in Ubuntu ??????
I dont understand! Reader is recognised, but its failing to read the card ok!
tank30 is offline
Old 16-09-2009   #9
B16MCC's Avatar
I have the sly italia card working in Ubtuntu and Omnikey.
You have not entered your boxkey in your newcs.xml.
I'm pretty sure it needs it mate.
I have it in mine and mine is working great
I also block GA emm's just for safety and put the card back in the original box every 6 weeks for an update.
B16MCC
B16MCC is offline
The Following User Says Thank You to B16MCC For This Useful Post:
tank30 (16-09-2009)
Old 16-09-2009   #10
My System: dm7020 dm600 p4xp dualcore ubuntu minipc debian
hello
can you confirm you're using a 93b sky it card with newcs and omnikey?
please can you tell us the ecm time of the card with this reader?
i've it but i don't use because with the nds2 card (0919) ecm are 210ms and under linux for the moment we can not change the clock , it is possible only under winxp.
tambuto is offline
Old 16-09-2009   #11
are you using latest newcs?
regards
F
tambuto is offline
Old 16-09-2009   #12
Hi , I am using newcs 1.67.
PS.
Newcs worked by adding the boxkey ( cheers B16MCC) but i have the weirdest problem. All channels work except from CALCIO channels (except calcio 3 which opens ok). I have posted newcs and client debugs but its pending forum admin approval...
tank30 is offline
The Following User Says Thank You to tank30 For This Useful Post:
tambuto (16-09-2009)
Old 16-09-2009   #13
rolfw's Avatar
Real name: Rolf
Thread closed. It is acceptable to discuss general card sharing techniques, but please do not list entire log files with HEX information.
Rolf
rolfw is offline
Closed Thread
167, card, newcs, sharing
