Card Sharing with DM 800, newbie needs help please
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 19-08-2009   #1
My System: computer setup : 8gb ram 500 gb harddrive windows server 2008
Hi guys,
Am new to the forum, after reading through out the forum for an hour, I thought I will post my problem hoping you guys would help.
Am about to buy a DM800 tomorrow for card sharing purposes I have 2 different cards (Showtime & Orbit) that I would like to share them with couple of my friends. Am a total newbie when it gets to these kind of stuff, but I have been reading for sometime now. I have a 4mb adsl connection, which I hope is enough anyways I will start with my questions, forgive me for my noobness
1)to my understanding so far, with each DM800 I can share 1 card ? that means if i want to share 2 cards, then i need 2 DM800 ?
2)A part from a internet connection, cards, PC and the Dm800 do I need any other hardware's ?
3)Is this something that I can manage alone ?
4)so far I know that for sharing I need a image and there is alot of different types out there, which one is best for sharing ? gemini ?
5)After installing the Image , I have to install CCcam ? I already managed to get 2 different types of tutorial for CCcam so I will follow one of them
that's all for now, I would appreciate any help, as a payback for your helps, If my card sharing did go successful, I will share a tutorial of the steps I took with your helps for other newbies like me.
Regards
Omid
omid888 is offline   Reply With Quote
Old 19-08-2009   #2
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
Talking Some Answers for you.
Originally Posted by omid888 View Post
Hi guys,
A: You may be able to use an external card reader for your 2nd card. The smargo smartreader+ for example. Do the research to see if the cards you want to run can be used in such a reader
A: You'll need a Router.
A: Yes definately
A: There isn't an image for sharing specifically, using the DM800 you should run Nabilo Blackhole , no question about it. Its by far the best image and feature packed.
A: Using Nabilo you can install the needed addons including CCcam from the addon server included in the image.
A: There are plenty of tutorials covering everything you need to know here on the site.
Regards
Omid
I hope this helps you. You should spend at least a week reading the Stickies section.
There are 10 types of people in the world. Those who understand binary and those that don't.
Check Out My Blog :- Dreambox Utils For Windows
Best Regards, Your Friendly Dreambox Gimp.
B16MCC
B16MCC is offline   Reply With Quote
The Following User Says Thank You to B16MCC For This Useful Post:
omid888 (22-08-2009)
800, card, newbie, sharing
