How To Install Omnikey Reader On Dreambox
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 15-10-2009   #51
My System: Dreambox 8000HD S, Dreambox 7025i, Fibo 1.2 fixed on 7W, 90cm Motorised System.
Thanks B16MCC,
I understand what you are saying in your post and when I carry out your instructions viz ./newcs_1.67.pcsc -c /var/tuxbox/config/newcs.xml (as well as others)I do get the message 'ready to go'. However when I try to start MgCamd-1.30 it won't (start). I feel that there is something missing in my newcs.xml. Can you (or anyone running MgCamd) tell me how many lines you have in your newcs from Device to Device (I hope that's clear) I have 13 begining with <name,<type,<node,<mhz,<export,<enabled,<blocksa,< blockua,<blockga,<blockc0,<carddetect,<newcamd_por t,<priority. I think that the responses ie the middle bits are accurate but if I can at least confirm that I have the right number to start with. I'll get there in the end, if what I am saying is frustrating you all please accept my apologies. as a matter of interest it is working perfectly in the top slot of my DM7025. I am running Nabilosat BH11.
Regards
woodseaves is online now   Reply With Quote
Old 15-10-2009   #52
andel's Avatar
My System: DM800 Panasonic 42" Plasma 1080p Pioneer VSX-LX70 Amp Sky HD B & W 5.1 Speaker Setup Popcornhour Media center Xbox 360
try
/usr/bin/mgcamd_1.30d
to start mgcamd
andel is offline   Reply With Quote
The Following User Says Thank You to andel For This Useful Post:
woodseaves (15-10-2009)
Old 15-10-2009   #53
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
The newcs.xml has nothing to do with starting MGCamd. If you install MGCamd from the addons panel and start it in the normal way in the blue panel it should start just fine.
The files of interest for MGCamd are :-
/var/keys/newcamd.list
/var/keys/camd_cfg
The second one may vary a little it seems due to version of MGCamd.
There are 10 types of people in the world. Those who understand binary and those that don't.
Check Out My Blog :- Dreambox Utils For Windows
Best Regards, Your Friendly Dreambox Gimp.
B16MCC
B16MCC is offline   Reply With Quote
The Following User Says Thank You to B16MCC For This Useful Post:
Old 15-10-2009   #54
Thanks, I am aware of newcs.xml having nothing to do with starting MgCam and also the other two points. What I am trying to get right is the contents of the omnikey device section of the newcs.xml
I agree that MgCamd does start from the blue panel, as a matter of interest the caid is showing in the omnikey as 0900
Is it not allowed for someone to pm me a working newcs.xml for the omnikey?
Old 15-10-2009   #55
andel's Avatar
/var/keys/camd_cfg
if you downloaded v1.30d from the blue panel on BH0.11 the it will be /var/keys/mg_cfg
Old 16-10-2009   #56
To B16MCC,
In your config creator advanced mode the Newcs external readers is greyed out, apart from name,type and node, what other differences are there between the internal and external (omnikey) newcs?
Regards
Old 16-10-2009   #57
B16MCC's Avatar
That option hasn't been implemented yet. It will follow eventually.
There are several parameters that differ between sci (internal) and external readers. Certain params are simply not used on the sci device. This is all detailed in the files included with every NewCS release.
B16MCC
Old 16-10-2009   #58
My System: DM 500S
@ B16MCC Where to find newcs.mips.pcsc ????
satter is offline   Reply With Quote
Old 16-10-2009   #59
andel's Avatar
google newcs-1_67RC1
its on rapidshare
Old 17-10-2009   #60
My System: DM 500S
@B16MCC will the omnikey 3021 do also? It is just 12 euro.
I bought a 3121 and am very happy with it it works 100 times better then smargo. But still 24 euro.
The omnikey 3021 is just 12 euro and i saw they use the same drivers as the 3121.
Old 4 Weeks Ago   #61
My System: iMac 20". Custom HTPC. DM800 HD. Full Sky HD Package. Panasonic 42" Full HD Plasma. Panasonic BD80 blu-ray. Onkyo 876 Amp. Jamo S606 speakers
Originally Posted by roaaul View Post
i have 6 omnikeys running now + 1 infinity usb smart
with viaccess, nds2 , nds3 all running fine
u sure u haven't got a port conflict?
also what hub are you using ?
i believe some hubs can be a problem
when ur watching c4hd on both boxes ur only using 1 of the cards thats why its not glitching only 2 control words from 1 card is being requested.
R
ok, i've checked ports are they are using different ports. does it make a difference how "far" the ports are away? i've got the irish card on 12678 and the UK card on 12679. are those port numbers too close?
moelikepie is offline   Reply With Quote
Old 4 Weeks Ago   #62
B16MCC's Avatar
lol, no mate they're not too close. They won't colide....
B16MCC
moelikepie (4 Weeks Ago)
Old 4 Weeks Ago   #63
i'd thought that alright, cause i've never had problems with other devices and port numbers beside each other but i thought dreamboxes might be a different beast! i'll stick my dunces hat on now!
Old 3 Weeks Ago   #64
hey guys & girls
i need some serious help here! i've tried everything that comes to mind with my limited knowledge of dreamboxes and i've been reading over tons of threads and still cant get this sorted.
i have two omnikeys 3121 with an irish card in one, uk card in the other. in newcs.xml both readers are set up with different port numbers. under newcamd server i have ONE user with username & password set as CCcam. (i have also tried 2 separate users and specified the port number for each user to a diff card)
then in my cccam.cfg i have the two n lines
n: 10.0.1.100 12678 cccam cccam 01 02 03 04 05 06 07 08 09 10 11 12 13 14
n: 10.0.1.100 12679 cccam cccam 01 02 03 04 05 06 07 08 09 10 11 12 13 14
and one F: line going to a box on my local network. server listen port is 12000
i have the server box on discovery HD (cleared via irish card) and the blue panel shows it connecting to the correct port number for the irish card, 12678. on my second box i have it on Channel 4 HD (uk card only) and its showing the address of 10.0.1.100:12000. but every 4-5 seconds both boxes are freezing. when both are on a channel from the same card all is perfect.
i have checked and double checked all my port settings so if anybody has any other ideas or a working newcs.xml & cccam.cfg for 2 (or more) cards that i could have a look at (via PM of course!) and edit for my own situation i would appreciate it a lot.
thanks very much for al the info so far
adam
Old 3 Weeks Ago   #65
WildBit's Avatar
My System: -DM800 fixed on 28.2-quad -DM7020 motorized -Skystar HD2 motorized -Cards&Cams&Cas
You will need unique users for each connection to your card (using the N line).
The F line is used for clients to connect to YOU! (CCcam)
According to your post, your newcs is listening on ports 12678 and 12679; how does your F line fit with this????
Originally Posted by moelikepie View Post
hey guys & girls
adam
WildBit is offline   Reply With Quote
The Following User Says Thank You to WildBit For This Useful Post:
moelikepie (3 Weeks Ago)
Old 3 Weeks Ago   #66
sorry, i meant to say i have a c: line in my server cccam.cfg and an f: line in my client box in the other room.
my f line on the client box is F: 10.0.1.100 12000 user pass
the 12000 is the server listen port i have set in the server cccam.cfg
i did have 2 users on my cccam.cfg like this
n: 10.0.1.100 12679 cccamuk cccamuk 01 02 03 04 05 06 07 08 09 10 11 12 13 14
and then the F: lie on the client was F: 10.0.1.100 12000 user pass.
my newcs is istening
<listening-ip>10.0.1.100</listening-ip>
and then for each reader i have
<newcamd_port>12678</newcamd_port>
for the users i have (with other details as well but i dont want to post too much in case its against the rules)
<name>CCcam</name>
<password>CCcam</password>
<port>12678</port>
so when i add the second user its
<name>CCcamuk</name>
<password>CCcamuk</password>
<port>12679</port>
its driving me mental cos i know its something simple!
cheers
adam
Old 3 Weeks Ago   #67
WildBit's Avatar
OK, the N lines are ok if you use the second user (cccamuk)
I'm still having problems trying to understand your F line though and this is where I susupect your problem is. How many boxes (clients) do you have? 2 at least from what you write... With the 1st box, you connect to your server (10.0.1.100) through the N lines, is this also yout CCcam server? If so, with the second client than you will connect with a C line (F line in server cccam.cfg) directly to CCcam which has the cards shared.
Old 3 Weeks Ago   #68
i have my dm800 as a server with newcs reading the cards and then sending that to cccam. i then have a dm800 in a different room in the house that connects with cccam to my server. that is my only client that im trying to get working. i have 4 mates with dm800 as well but i've disconnected all those clients until i get this working.
in my server cccam i have a single C: line
C: user pass
on my client i have a single F: line that is
the 12000 in that f line is for the server listen port of cccam on my server dm800.
Old 3 Weeks Ago   #69
WildBit's Avatar
Your server 10.0.1.100 is also your CCcam server (which connects to your cards via newcs).
The F line goes on the SERVER 800 box; which should be the 10.0.1.100 machine.
The C line will Connect to your server so it should look like something like this "C: 10.0.1.100 12000 user pass"
It appears that you are confusing the client and server roles
C: user pass
Old 3 Weeks Ago   #70
sorry, i am getting confused here. yes on my server i have f lines and the clients have c lines. i presume my c & f lines are working fine as the card is sharing from my server to the client. the problem is when the second card tries to come in.
im gonna try it all again here now. when im adding the users to NewCS, should i specify the port number? (using the config creator didnt add these port numbers to the user section of newcs) eg:
<user>
<name>CCcam</name>
<au>on</au>
<sidoverride>off</sidoverride>
<spider>no</spider>
<cardlevel>1</cardlevel>
<rate>1</rate>
<port>12678</port>
</user>
<user>
<au>on</au>
<spider>no</spider>
<rate>1</rate>
<port>12679</port>
</user>
and then in cccam.cfg SERVER
N: 10.0.1.100 12678 CCcam CCcam 01 02 03 04 05 06 07 08 09 10 11 12 13 14
N: 10.0.1.100 12679 CCcamuk CCcamuk 01 02 03 04 05 06 07 08 09 10 11 12 13 14
F: user pass
then in CCcam.cfg CLIENT
i've just tried this setup and its giving the same issues
Old 3 Weeks Ago   #71
WildBit's Avatar
you have
C: user pass
it needs to be
in my server cccam
F: user pass
on my client
Then check your newcs console through web http://10.0.1.100:8080 (if 8080 is the port in newcs.xml)
Old 3 Weeks Ago   #72
you have
C: user pass
it needs to be
in my server cccam
F: user pass
on my client
yes i realised after i posted that info that i had it arse about face, i dont actually have it that way i just got confused when posting.
from my previous post
"sorry, i am getting confused here. yes on my server i have f lines and the clients have c lines. i presume my c & f lines are working fine as the card is sharing from my server to the client. the problem is when the second card tries to come in."
sorry about all this but its doing my nut in and im sure im annoying other people as well but i dont see anything that i have wrong, hence all the questions etc
thanks again
adam
Old 3 Weeks Ago   #73
WildBit's Avatar
Now I'm the one that's confused ;-)
Let's see if this is right:
* DM800 server running CCcam + newcs with 2 omnikey readers (Node 0 and 1)
* Cards are enabled and displayed through newcs web interface
* Client dm800 box not connecting to dm800 server box
Old 3 Weeks Ago   #74
YES DM800 server running CCcam + newcs with 2 omnikey readers (Node 0 and 1)
YES Cards are enabled and displayed through newcs web interface
YES Client dm800 box IS connecting to dm800 server box
sorry, maybe i didnt make myself clear enough. the boxes are communicating perfectly. they can both read the Irish card AND can both read the UK card no problem, perfect picture. The problem is that when one box tries to read the Irish card and the other tries to read the UK card, BOTH boxes start to freeze & glitch every 4 - 5 seconds.
Old 3 Weeks Ago   #75
WildBit's Avatar
Finally a clear picture on what you are doing
The cards probably have the same CAID and therefore you will need to tweak the priority file. Why use both???
dreambox, install, omnikey, reader
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
woodseaves
