How To Install Omnikey Reader On Dreambox
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 3 Weeks Ago   #76
My System: iMac 20". Custom HTPC. DM800 HD. Full Sky HD Package. Panasonic 42" Full HD Plasma. Panasonic BD80 blu-ray. Onkyo 876 Amp. Jamo S606 speakers
Originally Posted by WildBit View Post
Finally a clear picture on what you are doing
The cards probably have the same CAID and therefore you will need to tweak the priority file. Why use both???
i knew we'd get here in the end!
i have the irish card for everything, and i have the uk freesat card for Channel 4 HD.
yes both cards are 0963. do you know what i have to change to make the cards work?
moelikepie is offline   Reply With Quote
Old 3 Weeks Ago   #77
WildBit's Avatar
My System: -DM800 fixed on 28.2-quad -DM7020 motorized -Skystar HD2 motorized -Cards&Cams&Cas
You can add an entry in the CCcam.prio file but I don't know if it will work with 2 identical cards
WildBit is offline   Reply With Quote
The Following User Says Thank You to WildBit For This Useful Post:
moelikepie (3 Weeks Ago)
Old 3 Weeks Ago   #78
ok, i'll look into that. at least i know what im looking for now.
thanks very much wildbit,
cheers
adam
Old 3 Weeks Ago   #79
WildBit's Avatar
If you really want to look into this then I suggest you look at cccam.cfg as well, you might be able to filter the channel directly through the C line. It would be a lot simpler if the second reader was installed on the second box
Old 3 Weeks Ago   #80
i was thinking this alright but the second box isnt always going to be at home, it'll be brought to our other house quite a bit so i'd rather not do this.
anyway, i'll start doing some reading and post here if i find anything. thanks again
Old 3 Weeks Ago   #81
My System: Dreambox 8000 HD PVR, 80cm Dish, 1.2 Compatible Motor, Quad LNB, Porty TV, Yamaha RX-V765 Amplifier, Tannoy Mercury FC Centre Speaker, 2 x Tannoy F1 Custom Speakers, 2 x Tannoy FR Custom Speakers, EPOS ELS Sub Woofer
can you not just use a dns address on the second box and tell its address to update via inadyn, that way when you move the box to another house, the dns address can still be accessed, just on a separate ip address.
Sharkadder is offline   Reply With Quote
Old 1 Week Ago   #82
My System: Irish Sky sub, Freesat HD from 28.2 East, BIS 5W and a Motorised Dish with a HTPC holding it all together
Right - got my Irish card in the Omnikey reader, and everything is now working nicely.
I use the latest Nabilosat Blackhole image for my DM800 and have finally managed to get NewCS configured and running. I use MGCamd 1.30d in the DM800 and what I like about this is that the card is not running hot at all!
What I really would like to do now is to start NewCS up when the DM800 starts up. At present I telnet to the DM800 and invoke the newcs command /usr/bin/newcs_1.67.pcsc -C /etc/tuxbox/newcs.xml command string - where should I start, and if a particular file is edited can someone tell me what directory the file lives in?
Crusty Burke is offline   Reply With Quote
Old 1 Week Ago   #83
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
/etc/init.d/bootup
There are 10 types of people in the world. Those who understand binary and those that don't.
Check Out My Blog :- Dreambox Utils For Windows
Best Regards, Your Friendly Dreambox Gimp.
B16MCC
B16MCC is online now   Reply With Quote
The Following User Says Thank You to B16MCC For This Useful Post:
Crusty Burke (1 Week Ago)
Old 1 Week Ago   #84
shumifan50's Avatar
My System: 2xDM7025(DVB-S tuner), DM600SPVR, DM800S, TM9100, Triax 90cm with MultiBracket 4 sats.
You could add the line to /user/script/mgcamd_1.31_cam.sh.
If you look in this file you will see a "case" statement with "start)" followed by running of "/usr/bin/$CAMD_BIN &". Insert your execution line just before it.
There is also a "stop)" case where the cam is killed. You should add a line
"killall -9 newcs_1.67.pcsc" just before the exisitng killall.
By doing this the cam will properly get stopped and started through the blue panel when you stop and start mgcamd. I noticed that the script does not support "restart", so when using the blue panel it is advised you do a "stop" and then a "start" of the cam.
NOTE: adjust your filenames and commands to suit mgcamd 1.30 - the above is for 1,31.
shumifan50 is offline   Reply With Quote
The Following User Says Thank You to shumifan50 For This Useful Post:
Old 1 Week Ago   #85
Thanks a million - made the changes as suggested and now Newcs starts automatically on startup.
Old 1 Week Ago   #86
My System: Dream 800HD, 1.1m motorised dish
Still trying to get my Omnikey 3121 to work on my DM800.
On the USB ports which way are they numbered ?
Is bottom one node 0 and the top one node 1, or, the top one node 0 and the bottom one node 1 ??
romcard is offline   Reply With Quote
Old 6 Days Ago   #87
_http://www.megaupload.com/?d=CZVLYHCH
use this to replace the version in /usr/bin as it is the pcsc file renamed
Old 6 Days Ago   #88
My System: Dreambox 7025 XPS Quadcore
I have been trying for 3 days now to get the omnikey reader to work on my db 7025.It just won`t work.I`ve gone over B16MCC`s excellent post at the thread start a thousand times and still no joy.I`ve loaded the drivers needed to use the omnikey.But when I try to start the file newcs.mips.pcsc, which I have renamed to newcs_1.67.pcsc,using telnet I get the message it can`t be found.My db just doesn`t see the reader.
help!!!
BB.
blaydonboy is offline   Reply With Quote
Old 6 Days Ago   #89
After trying to get my db internal reader to read my new sky white card,I finally succeded using newcs 1.66 and Cccam 2.1.1.However I now have two problems,one is I want to continue to let the cs I`m in see my card and two I want to use an external reader to read my card as I have heard about heating problems with the card,I`m not so happy to leave it in the internal reader.I have tried for 3 days now to get my omnikey reader to operate in my db 7025.I have went over B16MCC first post a thousand times with no joy.I can load the drivers needed in my db no problem.I`ve also loaded all the files I get from the newcs-1_67RC1 download.I rename the newcs.mips.pcsc file to newcs_1.67.pcsc and then try to start it through telnet,but I get the message file not found.
Help!!!!!
BB.
Old 6 Days Ago   #90
Sorry for the double post,I didn`t think the first one had gotten through.
BB.
Old 6 Days Ago   #91
andel's Avatar
My System: DM800 Panasonic 42" Plasma 1080p Pioneer VSX-LX70 Amp Sky HD B & W 5.1 Speaker Setup Popcornhour Media center Xbox 360
have you tried the full path via telnet.....
/usr/bin/newcs_1.67.pcsc -C /etc/tuxbox/config/newcs.xml
andel is offline   Reply With Quote
Old 6 Days Ago   #92
Thanx for the quick reply Andel.Well that line produced a lot details,but still no joy with the reader.I`m now doing a clean install of my image and I will try again.Can you tell me if I should install all the files I get from the newcs-1_67RC1 download@ Or do I just install the newcs.mips.pcsc file and rename it?
BB
Old 6 Days Ago   #93
andel's Avatar
no its just the newcs.mips.pcsc you need
What happens if you telnet and enter dmesg.
Do you see the omnikey listed?
Old 6 Days Ago   #94
omnikey AG shows in the details when I telnet dmesg.
BB.
Old 6 Days Ago   #95
andel's Avatar
ok so start newcs using
you should get "Ready to go"
then try to access the newcs web interface
Old 5 Days Ago   #96
Do what I suggested in post 87, works perfect as it is the pcsc file renamed. Overwrite the original file in /usr/bin and bobs yer auntie.
This way it works on it's own every boot, no need to telnet or anything.
Make sure you use common interface or summat while you overwrite just in case.
Then select the combined cam and away you go.
Obviously you still need to install the 4 files as well.
Old 5 Days Ago   #97
Sorry for being thick here,but where is web interface and how do I open it?
Thanx.
BB.
Old 5 Days Ago   #98
I just keep getting a loop saying reset failed.
BB.
Old 5 Days Ago   #99
andel's Avatar
paste
_http://your_dreambox_ip:8080
into your browser but replace with your correct ip address (and remove the _ at the start)
eg _http://192.168.1.2:8080
Old 5 Days Ago   #100
B16MCC's Avatar
Just a quick note before anyone asks, You cannot use an Omnikey reader with the new CCcam 2.1.3 or any other CCcam. CCcam does not support PC/SC.
B16MCC
dreambox, install, omnikey, reader
