Newcs + omnikey reader
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 08-09-2009   #1
My System: dm600pvr
Im trying to help a m8 out getting his white card working with newcs + cccam
this is running on a ubuntu desktop 9.04
card reader = omnikey 3121
pcsc_scan shows the card inserted and recognises it
got newcs.i686.pcsc in /var/bin and it runs
 sudo /var/bin/newcs.i686.pcsc -C /var/etc/newcs.xml
this runs and outputs
[ 20:09:28 ] [ NDS ] Status Word from Card: 9020
[ 20:09:28 ] Card reader unlocked for reader Omnikey [0]
[ 20:09:28 ] [ 0963 ] Init took: 0.775605
[ 20:09:28 ] [ Loader ] Card 0963 on port 0 ready
[ 20:09:28 ] [ Card queue 0 ] Starting...
[ 20:09:28 ] [ Loader ] Starting Newcamd Server on port 12010
[ 20:09:28 ] [ Newcamd ] Newcamd thread Server started on port 12010
newcamd: main loop
[ 20:09:28 ] [ NewCS ] Ready to GO! :)
then drops to the prompt, but running ps -e shows newcs as a running process
should it or should it run in debug mode ..?? ie output what its doing to the screen
heres the newcs.xml
<newCSconfig>
        <readers name="Standard Omnikey on PC">
                <device>
                        <name>Omnikey</name>
                        <type>pcsc</type>
                        <mhz>368</mhz>
                        <node>0</node>
                        <parity>odd</parity>
                        <reset>normal</reset>
                        <export>Yes</export>
                        <enabled>Yes</enabled>
                        <boxkey>00000000</boxkey>
                        <blocksa>No</blocksa>
                        <blockua>No</blockua>
                        <blockga>Yes</blockga>
                        <blockC0>Yes</blockC0>
                        <carddetect>Yes</carddetect>
                        <newcamd_port>12010</newcamd_port>
                        <autosid>Yes</autosid>
                        <priority>round</priority>
                </device>
        </readers>
        <radegastserver>
                <port>10001</port>
                        <allow>
                                <hostname>localhost</hostname>
                        </allow>
        </radegastserver>
        <cache>
                        <emm>20</emm>
                        <ecm>-1</ecm>
        </cache>
        <httpd>
                <server>
                        <port>8080</port>
                        <enabled>yes</enabled>
                </server>
                <user>
                        <name>admin</name>
                        <password>admin</password>
                        <accesslevel>admin</accesslevel>
                </user>
        </httpd>
              <debug>
                        <password>NewCSpwd</password>
                        <mode>simple</mode>
                        <level>internal</level>
                        <type>all</type>
                        <output>console,tcp</output>
                        <tcp_port>1001</tcp_port>
                        <tcp_options>normal,init</tcp_options>
        </debug>
        <newcamdserver>
                        <name>newcs</name>
                        <deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
                        <user>
                                <name>CCcam</name>
                                <password>CCcam</password>
                                <au>on</au>
                                <sidoverride>off</sidoverride>
                                <spider>No</spider>
                                <cardlevel>2</cardlevel>
                        </user>
        </newcamdserver>
</newCSconfig>
could it be a libcrypto file missing...??
this is whats installed
 sudo find / -name libcrypto*
/lib/libcrypto.so.0.9.8
/lib/i486/libcrypto.so.0.9.8
/lib/i686/cmov/libcrypto.so.0.9.8
/lib/i586/libcrypto.so.0.9.8
/usr/lib/libcrypto.so.0.9.8
it dosnt seem to allow the card to be shared to CCcam
but if I run the same stup on my own ubuntu (server 9.04) and a blue house freesat card , newcs outputs everthing to the screen
renwich is offline   Reply With Quote
newcs, omnikey, reader
