Sharing externallyDreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Regular Member Join Date: 16-06-2009 Location: London
My System: DM800 Panasonic 42" Plasma 1080p Pioneer VSX-LX70 Amp Sky HD B & W 5.1 Speaker Setup Popcornhour Media center Xbox 360 |
Up untill now I've been sharing on my internal lan from my dm800 hosting my card to my dm500. This is my cfg on my dm800 Code: SERVER LISTEN PORT : 32452
N: 192.168.1.64 60000 dm800user dm800pass 01 02 03 04 05 06 07 08 09 10 11 12 13 14 2
F: dm500user dm500pass 32452 2 1 0 { 0:0:1 }
Code: N: 192.168.1.64 60000 dm500user dm500pass 01 02 03 04 05 06 07 08 09 10 11 12 13 14 2 I'm assuming that I only need to change the ip address in my dm500 cfg to show my external ip/dyndns. Is this right? I have tried all the above but while in telnet to newcs if I change the dm500 cfg ip it logs me out of newcs then logs me back in when I change it back. I have read that my particular (isp supplied) router, speedtouch dg585v6 does have its problems with port forwarding and many people have bridged this router to modem mode and used another router to port forward. Is there anyone that can help with checking my ports? Just thought I'd ask before going down the road of changing my router and ask if there is anything wrong with my cfg? | ||
| Dreambox Gimp & Coder Join Date: 16-11-2005 Location: /var/tuxbox/config
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | Your theory is correct. You are using N lines to access NewCS therefore you only need to forward the newcamd_port to the host box IP. The F: line in your DM800 is not needed, its not doing anything. Your DM500 is not connecting to CCcam, its connecting to NewCS. | ||
| There are 10 types of people in the world. Those who understand binary and those that don't. ----------------------------------------------- Check Out My Blog :- Dreambox Utils For Windows ![]() Best Regards, Your Friendly Dreambox Gimp. B16MCC ----------------------------------------------- | |||
| The Following User Says Thank You to B16MCC For This Useful Post: | andel (11-09-2009) |
My System: DM800 Panasonic 42" Plasma 1080p Pioneer VSX-LX70 Amp Sky HD B & W 5.1 Speaker Setup Popcornhour Media center Xbox 360 | ok thats what I was thinking as when I added the n line to my dm800 cfg, that allowed me to view on that box however I did just have an n line in both cfg's but i think the reason I added the F line was that it was the only way i was getting a picture on the 500. Anyway Im not totally sure and arn't in a position to check at the min. Maybe its not a port forwarding issue and its something else. I might try changing the port too. Anyway ill check it out over the weekend and report back. Cheers | ||
My System: DM800 Panasonic 42" Plasma 1080p Pioneer VSX-LX70 Amp Sky HD B & W 5.1 Speaker Setup Popcornhour Media center Xbox 360 | ok....as usual b16mcc, you're are completely correct. its only an n line i need. So if i change the ip to my external address i am not connected. it must be a port issue, Is there a way to check if my ports are open? | ||
| | #5 | ||
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | I agree its very likely its a port forwarding issue. I can't advise exactly about port forwarding as there's so many routers out there. Check the settings in your router using your web browser. You'll need to forward port 60000 to the IP address of your NewCS server box. | ||
| | #6 | ||
My System: DM800 Panasonic 42" Plasma 1080p Pioneer VSX-LX70 Amp Sky HD B & W 5.1 Speaker Setup Popcornhour Media center Xbox 360 | yeah i have done that but i was just wondering if there was a way to ping/scan the port or something like that? | ||
| | #7 | ||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | Depends on the router. You can't ping your external ip from the lan unless the router has loopback. | ||
| The Following User Says Thank You to Huevos For This Useful Post: | andel (16-09-2009) |
| | #8 | ||
| Manic Midlander Moderator Join Date: 24-09-2006 Location: West Midlands. UK
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | Have you enable port forwarding to both UDP & TCP or just one or the other ![]() If you are unsure of how to set your router up please checkout this web page. _http://portforward.com/ ![]() Nano | ||
Sanity is nothing more than an excuse to be boring <<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>> <<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>> <<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>> | |||
| | #9 | ||
My System: DM800 Panasonic 42" Plasma 1080p Pioneer VSX-LX70 Amp Sky HD B & W 5.1 Speaker Setup Popcornhour Media center Xbox 360 | yes I'd already been there just to check I was doing it right as the interface is really un-user friendly. It seems I am doing it correctly. The router is a Speedtouch 585 v6 supplied by bethere. I found this site which can check your open ports _http://www.auditmypc.com/firewall-test.asp it does report back that my port is open for tcp although I have opened it for both tcp& udp, will this matter? I've also been here _http://www.adsl2forum.co.uk/showthread.php?t=9968 which is where it seems lots of people have given up trying to forward ports and bridged the router instead. At the moment I havnt moved my second box but still have it on my LAN. Should this matter that I'm changing the ip for the external one while the box is still local? (i just thought i'd set it up before moving it) | ||
| | #10 | |||
My System: DM800 Panasonic 42" Plasma 1080p Pioneer VSX-LX70 Amp Sky HD B & W 5.1 Speaker Setup Popcornhour Media center Xbox 360 | | |||
| | #11 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | It's pretty simple really. If the client is connecting from the LAN they should use the cardserver LAN ip. If the client is connecting from outside the LAN (i.e. the internet) then the WAN ip should be used. | ||
| externally, sharing |
