BT Business hub/DreamboxDreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Member Join Date: 11-05-2008 Location: Wales
My System: fortecstar Sky+ |
Bought a BT business hub and unlocked it to work on any network, but I have a problem with my dream box the hub can’t see it! I think I need to open a port on the hub have tried different things but no luck any help appreciated | ||
| Dreambox Gimp & Coder Join Date: 16-11-2005 Location: /var/tuxbox/config
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | This is unlikely to be a Dreambox problem. The device you've bought, is it a hub/switch or is it in fact a router ? If its a router have you enabled DHCP on the dreambox ? | ||
| There are 10 types of people in the world. Those who understand binary and those that don't. ----------------------------------------------- Check Out My Blog :- Dreambox Utils For Windows ![]() Best Regards, Your Friendly Dreambox Gimp. B16MCC ----------------------------------------------- | |||
My System: fortecstar Sky+ | Hi yes the dream worked ok with my netgear this hub is a modem router and it seems to be the firewall stopingthe dream had a look on the net and read the instructions on the modem but i cant get my head round opening the port | ||
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | Yeah it seems your problem is with the router. I'd recommend a nice netgear, it just works ! | ||
| business, hub or dreambox |
