Originally Posted by scousa80 i am not asking for a image iam asking for the files that i can ftp to my box and the sly card to work in my db 800hd onces this works i want to move onto the csharing i been on here for 12 hours now i am getting a omnikey reader 2mra and i wont to no can i just plug the omnikey reader in as i have done the following and will it work
1. ipkg install /tmp/libusb_0.1.12-r0_mipsel.ipk
2. ipkg install /tmp/pcsc-lite_1.5.5-r0_mipsel.ipk
3. ipkg install /tmp/libpcsclite1_1.5.5-r0_mipsel.ipk
4. ipkg install /tmp/ccid_1.3.11-r0_mipsel.ipk |
Originally Posted by scousa80 an i am asking people with the same box as mine the db 800hd not any other box |
The point is that you cant just FTP someone elses files to your box. When you run 'ipkg install ......' You are installing a package of files/libraries which could be installed in many different directories on your box. Thats the easy way of doing it.
FTPing all those individual files to your dreambox and finding the correct location to put them would be a nightmare even for an experienced user.
Your getting ahead of yourself by installing the libraries ect for your card reader when you haven't even managed to get the box to read your card.
Break it down into steps and dont start one step till the previous one is complete.
1: Get the box to read the card in the built in reader. (Check that its not getting too hot).
2: Set up your Clines and Flines to test sharing. (Keep checking that its not getting too hot).
3: Install and configure your external card reader.
Also,
you still haven't said whether you are using the white or blue card? People are having to assume you are using the white card.
