Ok, here's a quick run down, in order, of what you need to learn to achieve your goal. Some of which you already have done of course.
Setup Network.
How to flash your Dreambox. (Using sly UK you're gonna want to use Nabilo Blackhole Image ).
Familiarise yourself with the menus.
Learn how to install addons from the addon panel.
Learn how to install addons manually using FTP and Telnet.
Learn about Card servers and Cam emulators.
Understand the theory of the difference between the two and their associated config files, for example :-
NewCS and the config file newcs.xml
CCcam and the config file CCcam.cfg
Learn about the importance of a boxkey and how to generate it.
You will need to keep your sly uk box installed to update your card every 6 weeks. ( using current methods at least for now ).
Read as many tutorials as you can find. Then read them again.
Then try to implement them, then read them again.
Stick with it and ask if you get stuck, don't ask before you've tried it and don't ask without reading and searching.
You didn't seem to acknowledge a very important point I made earlier, the NewCS you installed from the addons panel WILL NOT WORK with the Omnikey, you need a different one, not available on any addons panel. Read the omnikey tutorial very carefully. |
