Newcs+cccam2.1.1 stuttering every 10 seconds
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 25-09-2009   #1
My System: DM7025 DM600 x 2 DM100 x 2
Does anybody have any ideas what would cause stuttering every ten seconds on a local card the configuration is
LT5 sp8 - Newcs 1.65 - CCcam 2.1.1
the debug from cccam gives the following
log removed - admin
What is a
newcamd read failed 0
or
newcamd receive error -1
any help would be appreciated
vampsthevampyre is offline   Reply With Quote
Old 25-09-2009   #2
sonic1's Avatar
My System: Dreambox 7020si,SIF 1.9.4- Dreambox 800HD Nabilo BH 0.12 Netgear adsl router, 98cm Funkee on Diseqc motor, Maintaining Hummy 5400 for the old man!
Can you post your newcs.xml ?
sonic1 is offline   Reply With Quote
Old 25-09-2009   #3
will do as soon as i get home, although it was the standard one produced by B16MCC's config creator
Old 25-09-2009   #4
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
update to NewCS 1.67 mate. 1.65 will not run a 0963 card !
There are 10 types of people in the world. Those who understand binary and those that don't.
Check Out My Blog :- Dreambox Utils For Windows
Best Regards, Your Friendly Dreambox Gimp.
B16MCC
B16MCC is offline   Reply With Quote
Old 25-09-2009   #5
shumifan50's Avatar
My System: 2xDM7025(DVB-S tuner), DM600SPVR, DM800S, TM9100, Triax 90cm with MultiBracket 4 sats.
Have you checked your ecm.info to be sure it is clearing you from your own share and not going outside?
I found that I had to uncomment the location of the CCcam.prio in CCcam.cfg and insert one line into the file:
P: 0963:0961
This forces the cam to use 0963 before 0961 even when both are 1 hop, otherwise, it seems, it takes 0961 before 0963, doesn't matter what the position of your N line in CCcam.cfg is.
shumifan50 is online now   Reply With Quote
Old 25-09-2009   #6
Lt5 doesnt have that as an option, and I've never done manual installations (besides from your tutorial on the omnikey)
is it possible to just overwrite and chmod with the new version? - i.e with the pcsc version for the omnikey?
Old 25-09-2009   #7
sonic1's Avatar
oops missed the bleedin obvious there
Old 25-09-2009   #8
Shumifan50 yes I had the same problem of it reading an external 961 card before my 963, but i followed your advise last time and added the prio file and also disconected from the network just to be sure it wasnt escaping outside (thinking about it would it have been better to # out the c line?)
and it still gives me the 10 second stutter
Old 25-09-2009   #9
shumifan50's Avatar
Before doing anything below make a backup of /etc/CCcam.cfg and /etc/tuxbox/config/newcs.xml.
Get CCcam 2.1.2 at _http://www.eurocardsharing.com/f78/cccam-2-1-1-new-download-here-122241 - you have to register.
Get newcs 1.67RC1 at _http://www.cardserver.org/cardsharing/f58/newcs-1-67-rc1-21082/
unzip the CCcam so you have a .tar.gz file. Copy it to /tmp on STB.
Then in telnet session:
cd /tmp
tar -zvf <the .tar.gz file>
Copy your CCcam.cfg and newcs.xml that you saved back.
You only need to copy newcs.mips.pcsc to /usr/bin/newcs_1.67 after installing CCcam.
using your dreambox remote from blue panel: select CCcam2.1.2 + newcs 1.67 and restart the cams.
Or you can do it all easily byusing the STBmanager script on this section. It gives you the option of overwriting the config files or not.
The Following User Says Thank You to shumifan50 For This Useful Post:
vampsthevampyre (25-09-2009)
Old 25-09-2009   #10
thanks for that; a faster responce than instant messaging, I'll give it a go as soon as i get home
cheers
Old 25-09-2009   #11
shumifan50's Avatar
This started happening to me too. After looking at everything, it turned out that th white card was not being handled correctly by newcs - through the web interface I reset the reader and the problem went away. You can see it by looking at User Status in the newcs web interface when you start getting high "Bd ECM" counts.
I will keep watching and try to work out why the Omnikey reader misbehaved.
Old 25-09-2009   #12
My System: Debian Lenny CCcam 2.1.2 + NewCS 1.67 ,dreamBox 500 dm600, compaq p4, 2gb ,4mb
ok this could also down too people adding 'The Trick' on there N line and sharing your card as there own,
THE ONLY ANSWER IS TO REPLACE ALL YOU N LINES WITH C LINES
darrenob is offline   Reply With Quote
The Following User Says Thank You to darrenob For This Useful Post:
shumifan50 (26-09-2009)
Old 26-09-2009   #13
Site administrator
Analoguesat's Avatar
Please dont post cam log files - we are trying to discourage it on the forum as its bound to lead to problems eventually.
Cheers lads - your cooperation is appreciated.
Analogue forever!
Analoguesat is online now   Reply With Quote
Old 26-09-2009   #14
shumifan50's Avatar
Darrennob :
it has nothing to do with N lines as I dont have any externally. Please remove the 'Trick' thing from your post, you will notice that B16MCC has done that too.
darrenob (09-10-2009)
Old 26-09-2009   #15
thanks for everybodies help it turned out to be the newcs version, updated to the latest 1.67 and everything is working perfectly thanks once again to shumifan50 and B16MCC (I think I'll just add that to my signature as its all I seem to be doing is thanking both of you), next thing to do now is work out what i've done to my omnikey as its stopped reading the card
I thing I've copyed the wrong version over to my dreambox, but make to the other thread and take it step by step again.
once again thanks to everybody
Old 26-09-2009   #16
shumifan50's Avatar
I have had the reader stop working several times. Reset through the web interface seems to solve the problem, but there is something not quite right. It might be a problem with newcs 1.67RC1 as oposed to newcs 1.67. I will experiment to get to the bottom of it.
Old 26-09-2009   #17
mines now back up and running, so i'll keep an eye on what is going on and see is it loses connection, as usuall thanks for all your help
cccam, newcs, seconds, stuttering
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
sboyd
