ip address & port number
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 26-09-2009   #1
My System: sab,technomate
do i need to register to get an ip address & name or will my static address be ok. also how do i know what port do i have to set is it a default the 12000.
hawaythelad is offline   Reply With Quote
Old 26-09-2009   #2
My System: Dreambox 500+; Echostar 770 (Strong 6155); 90cm Triax dish; Strong DM2100 diseqc motor.
Since you have a static ip, you don't need a dyndns account.
If you want to share your card over the internet, you need to forward 12000 tcp port.
kalehrl is offline   Reply With Quote
Old 26-09-2009   #3
so all i do is change the port number from 80 to 12000 tcp or is 12000 set as default
Old 26-09-2009   #4
shumifan50's Avatar
My System: 2xDM7025(DVB-S tuner), DM600SPVR, DM800S, TM9100, Triax 90cm with MultiBracket 4 sats.
you have to be more specific as to which IP you are talking about. Is your IP static IP internal or external and do you want to be visible only on your internal LAN or externally. Do you have a router? The port can be configured in the config file of the cam. Which cam do you want to use?
shumifan50 is offline   Reply With Quote
Old 27-09-2009   #5
I am using cccam 2.1.1 the static ip address is the one on the dreambox & yes i have a netgear router.
Old 27-09-2009   #6
Grimm Member
rick1980's Avatar
My System: 1.1m Triax Motorised 45e-45w, Raven 60cm fixed, Fortex Zeta PVR, Technomate TM500
Which means that you probably have a dynamic IP, via your ISP. The easiest way around this is to use a DNS host like DYNDNS. Basically this allows people to connect to you without changing settings regardless of what your external IP address is.
You can use any unused port for CCcam, though the default is 12000. You need to enable port fowarding on your router to whatever the server listen port is in the CCcam config file.
I've booted up, I've patched in, I'm online, offline, downloaded and extremely cheesed off!
rick1980 is offline   Reply With Quote
Old 27-09-2009   #7
so i get an address from dydns, so where do i enter that static address, do I just replace the address in dreambox.
Old 27-09-2009   #8
rolfw's Avatar
Real name: Rolf
No, if you have a router with the facility to enter a dynamic DNS address, do it there, my Netgear has a section for it.
Rolf
Old 27-09-2009   #9
i have set up an account with dydns, am I right that my servername wil be redirected to my ip address automaticly. the ip adddress is the one provided by my isp. I have set up my portforwarding to 12000 the default. do i have to do anything with my internal lan to the dreambox.
Or will they cumunicate without each other, without any changes to the dreambox.
Old 27-09-2009   #10
sorry for the typo at the end, got a cold coming on.
Old 27-09-2009   #11
Grimm Member
rick1980's Avatar
Your lan will work as before. The DNS is just so other computers outside your lan can always communicate with you. My netgear has a section for DNS, but your PC can update it when it's on. Instead of giving your IP address on your lines you give your DNS name, so for example a c line would be c: somedns.somehost.com port user pass.
Old 27-09-2009   #12
so my lan will work as normal, got that, understand how to set the cline up(great tutorial on that here). do i need to keep my router connected to my laptop to keep the dns upto date or not.
Old 27-09-2009   #13
Grimm Member
rick1980's Avatar
not if your router will keep the DNS up to date. Though you will only usually get a new IP address if your router reconnects. So you should be ok to let the laptop do it automatically when it reboots.
Old 27-09-2009   #14
cheers for the help, sorted now.
Old 27-09-2009   #15
compufunk's Avatar
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters
You can let the Dreambox handle the dynamic DNS updating.
The Nabilosat + Gemini images (probably the others too) have a pre-installed script for updating with Inadyn.
In gemini, you set it up under Blue Panel -> Services / Daemons -> Inadyn.
I cant remember where its set up on the Nabilosat images.
ip address & port number-screenshot-jpg   ip address & port number-screenshot2-jpg
compufunk is offline   Reply With Quote
Old 28-09-2009   #16
just one more quick
Old 28-09-2009   #17
just one more quick point, will the dydns update the ipaddress automaticly when i reboot my router. as my ipaddress is not a static address.
Old 28-09-2009   #18
compufunk's Avatar
Only if you've either set the router, pc or the dreambox to check your IP address and when necessary, update the address with your dynamic DNS provider.
Old 28-09-2009   #19
cheers will do via the router, thanx for all the help.
address, number, port
