multi-lnb setupDreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Member Join Date: 27-09-2009 Location: london
My System: Dreambox 500s+ |
im upgrading my ageing system next month. i currently have a cheap echostar, very very old. im looking into dreambox because of the opensource operating system and plugins. ![]() currently the dish is motorised. but im thinking of getting it fixed. my question is what satellites are the best for arab channels,sports,freesat,movies im currently of thinking of getting astra 28.2e for freesat and hotbird for morocco channels. someone suggested thor satellite is very good ? any ideas. please and is dreambox the preffered system is there anything similar that can be flashed with images. kind regards | ||
Welcome to the forum lixxus Well without knowing what size dish you have advise is difficult to give. A Dreambox is a hobbyist stb and requires weeks of learning about before you will be its master, I suggest you think again on your choice of stb unless you are extremely comfortable with Linux | ||
My System: Dreambox 500s+ | thanks for quick reply. the dish size is 120cm i am comfortable with linux. ive had experience flashing routers and similar device such as alix/wrap. its just a surpise to me i never heard sooner about satellite recievers that are linux compatible. i would very much appreciate some advice on the best satellites atm. im in london. and sick and tired of crap freeview signal so freesat 28.2e 2D is a must. ive done some reading and plan on using ccam for cardsharing. i wont go into detail as i dont know whether this talk is allowed on forum. but i prefer fixed because of weather here in uk. the rain and wind can mess up the alignment of satellite signals. i just cant decide on which satellites to use. also will 3 lnbs be overkill. and what lnb's and diseqc switch do you recommend. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | A good quality motorised dish will have no problem with the weather, can you take a couple of photos of your existing setup? | ||
| | #5 | ||
| Regular Member Join Date: 07-09-2007 Location: Europe
My System: 2xDM7025(DVB-S tuner), DM600SPVR, DM800S, TM9100, Triax 90cm with MultiBracket 4 sats. | You can look on Lyngsat to find the programs on satellites and make your choice. When you use a multi-bracket LNB setup, the closest 2 satellites can be is typically 3 deg, e.g 28.2 and 19.2 are easy 19.2 and 23.5 is very tight. You can get "narrow" LNBs that allow slightly closer setup. I prefer multi-LNB setups as there is no movement on the dish and switch time between channels on different satellites is instantaneous. | ||
| | #6 | |||
My System: Dreambox 500s+ | my main aim is to watch premiership football games and champions league. again i havent ordered my reciever yet. but i have heard clone dreamboxes have time bomb issue with flashing. is this true and are original dreamboxes unaffected. also can anyone recommend a retailer please | |||
| | #7 | |||
nabilo,PLI,Gemini anyone got any views please. i prefer one with a larger community and continuous updates and support | |||
| | #8 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | If you want Premiership football you are going to need access to a subscription card - there are almost no freebies these days even with the Linux boxes. The last compromised service (DigiTV on 1W) is expected to go secure in the near future. Subs cost anything up to £1500/year if you have to use a UK based reseller! Pukka Dreamboxes arent affected by the timebomb. Clones are and you want to stay away from Gemini images if you buy a clone. | ||
| | #10 | ||
| Dreambox Gimp & Coder Join Date: 16-11-2005 Location: /var/tuxbox/config
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | The only Retailer I would use is _www.satstore.co.uk , great service and support. There are others including the forum supporting advertisers. Nabilo are probably the best image around. Especially for the higher spec. boxes. For Premiership football your best bet is most likely sly italia . Check out _www.marconidigital.com for euro based pre payed cards. He does sly italia calcio and sports card and receiver for around £1200. | ||
| There are 10 types of people in the world. Those who understand binary and those that don't. ----------------------------------------------- Check Out My Blog :- Dreambox Utils For Windows ![]() Best Regards, Your Friendly Dreambox Gimp. B16MCC ----------------------------------------------- | |||
| multilnb, setup |
