Release:- NewCS & CCcam Config Creator v0.6.1
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Closed Thread
Old 29-09-2009   #1
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
Talking Release:- NewCS & CCcam Config Creator v0.6.1
Hi guys. Here's beta 6 of the NewCS CCcam Config Creator.
Change Log:-
Fixed several minor bugs.
Advanced mode is now active.
This gives you full access to almost all of the NewCS parameters. The reaming less popular ones will follow.
It also gives you access to add users to CCcam. The Advanced settings for CCcam is quite lacking at the minute. Again more CCcam parameters will follow in the next few releases.
There's been some great suggestions for future releases and they will be included but I've released this now as the Advanced mode involves so much more code and I'd like a little testing help please before we move forward any further. So , check it out and report back with your findings please.
I've started a new thread again as this is a minor version release and not just a bug fix release. This will be the format from now on.
Download Here
Release:- NewCS & CCcam Config Creator v0.6.1-newcs-cccam-config-creator-v0-6-0-jpg
There are 10 types of people in the world. Those who understand binary and those that don't.
Check Out My Blog :- Dreambox Utils For Windows
Best Regards, Your Friendly Dreambox Gimp.
B16MCC
B16MCC is offline
The Following 6 Users Say Thank You to B16MCC For This Useful Post:
andel (29-09-2009), Burnham Beech (29-09-2009), compufunk (29-09-2009), CROSSBONES (01-10-2009), moelikepie (29-09-2009), Tomdigital (01-10-2009)
Old 29-09-2009   #2
andel's Avatar
My System: DM800 Panasonic 42" Plasma 1080p Pioneer VSX-LX70 Amp Sky HD B & W 5.1 Speaker Setup Popcornhour Media center Xbox 360
thanks for your work, will check it out and post my results
Edit:- I'm using win7 and the NewCS External Readers button dosnt do anything. Is this still a work in progress feature?
andel is offline
Old 29-09-2009   #3
My System: iMac 20". Custom HTPC. DM800 HD. Full Sky HD Package. Panasonic 42" Full HD Plasma. Panasonic BD80 blu-ray. Onkyo 876 Amp. Jamo S606 speakers
thanks for all the work B16MCC
windows xp pro SP3 here and same issue
moelikepie is offline
Old 29-09-2009   #4
My System: DM7025 DM600 x 2 DM100 x 2
looking good, will give it a good battering tonight
keep up the excellent work
vampsthevampyre is offline
Old 29-09-2009   #5
B16MCC's Avatar
Wink
Sorry guys I obviously missed that. It's a feature that will follow and should have been disabled (Greyed out) in this release.
B16MCC
B16MCC is offline
Old 29-09-2009   #6
andel's Avatar
i've noticed the only default blocker set to yes is blockc0 is this now the recommended setting for sly?
andel is offline
Old 30-09-2009   #7
B16MCC's Avatar
In advanced mode the settings switched on are merely common settings. They are not meant to be recommended for anything in particular. For a Sly UK config use the simple mode and select it from the Preset list.
B16MCC
B16MCC is offline
Old 30-09-2009   #8
B16MCC's Avatar
Here's v0.6.1.
Just a few bug fixes with button control.
Download Here
B16MCC
B16MCC is offline
Old 30-09-2009   #9
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband!
can this programm also create,.cfg file for the wifi diablo?
when i copy the same from the dreambox into the wifi,i see that it connect to my wlan router but still not work,what is diffrent,in the cfg file that the wifi cam needs,can i also create this nesersary diffrent format,with this programm?
Turok is offline
Old 30-09-2009   #10
B16MCC's Avatar
You'd have to give me a lot more information on what you're trying to do mate. I've never heard of this wifi cam you mention. I take it its capable of connecting to a wifi router and then on to a NewCS / CCcam server by the sounds of it ?
Would you please make a new thread concerning this issue as its not really a problem with this software.
B16MCC
B16MCC is offline
Old 05-10-2009   #11
B16MCC's Avatar
Guys does anyone have any newcs configs useful for other popular cards ?
If you have any info please PM it, DO NOT post configs here. I'll add them to the Simple Mode Use Preset list in future releases. Thanks...
B16MCC
B16MCC is offline
The Following 2 Users Say Thank You to B16MCC For This Useful Post:
edit_21 (3 Weeks Ago), notropil (2 Weeks Ago)
Closed Thread
cccam, config, creator, newcs, release
