RS 232 with USBDreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Regular Member Join Date: 23-04-2009 Location: Dublin
My System: 1M Motorised Dish, DM 500s, Digital+, Sky+, TDT |
Hi, Can I use a cable that is USB on one end and RS 232 on the other for updating a Dreambox as I cant use a normal RS 232 as my laptop does not have the relevant slot. | ||
| Dreambox Gimp & Coder Join Date: 16-11-2005 Location: /var/tuxbox/config
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | Possibly. It really depends which one you have. Some work , some don't. Mostly those converters are an RS232 converter but not a full null modem. What DM do you have, can you not flash it via your router using the Web Interface ? | ||
| There are 10 types of people in the world. Those who understand binary and those that don't. ----------------------------------------------- Check Out My Blog :- Dreambox Utils For Windows ![]() Best Regards, Your Friendly Dreambox Gimp. B16MCC ----------------------------------------------- | |||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Me, I do. ![]() Why can't you connect to it via ethernet and use the web interface, it is much quicker and easier? I have used a usb-rs232 as well of course, for an old receiver. The one I had was not a null modem, so a null-modem cable had to be connected on the rs232 end. I believe you can buy them with the null-modem included, try Ebay | ||
| | #5 | ||
| Regular Member Join Date: 09-02-2008 Location: Ireland
My System: -DM800 fixed on 28.2-quad -DM7020 motorized -Skystar HD2 motorized -Cards&Cams&Cas | The web interface is your best option mate... the serial connection is a pain in the xxx particularly if you do not have the right cable; not to mention the speed advantage | ||
| | #7 | ||
| Regular Member Join Date: 07-09-2007 Location: Europe
My System: 2xDM7025(DVB-S tuner), DM600SPVR, DM800S, TM9100, Triax 90cm with MultiBracket 4 sats. | Read this thread - it is the same on most dreamboxes, just on 7025 you press the bottom button. Flash Your DM800 - The Easy Way | ||
| 232, usb |
