DCC connection problemDreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Regular Member Join Date: 23-04-2009 Location: Dublin
My System: 1M Motorised Dish, DM 500s, Digital+, Sky+, TDT |
Hi, Just at to installing Dreambox Control Centre DCC on my laptop and at to running the programme which is in german! says it is not connected. I currently have my Dream 500s connected to my router and the router to the laptop. Do I need to connect the Dreambox directly to the laptop via the Ethernet cable for this to connect or am I doing something wrong ? Thx | ||
| Dreambox Gimp & Coder Join Date: 16-11-2005 Location: /var/tuxbox/config
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | you have to tell DCC that you're using a router. You also have to tell it the IP address of the DM. You can select the language from a dropdown box if I remember correctly. | ||
| There are 10 types of people in the world. Those who understand binary and those that don't. ----------------------------------------------- Check Out My Blog :- Dreambox Utils For Windows ![]() Best Regards, Your Friendly Dreambox Gimp. B16MCC ----------------------------------------------- | |||
My System: 1M Motorised Dish, DM 500s, Digital+, Sky+, TDT | Thats brilliant. I done that and it recognises the Dreambox but now it wants my router IP ? How do I get that or is it just 192.168.1 by default ? EDIT: Found it | ||
My System: 1M Motorised Dish, DM 500s, Digital+, Sky+, TDT | Had DCC working yesterday but today I have gone into and keep getting "Error 10057 in function send socket is not connected". There is a green line from computer to router but line to the router is red. Any help appreciated. | ||
| | #5 | ||
My System: 1M Motorised Dish, DM 500s, Digital+, Sky+, TDT | Messag on DCC is saying check dreambox IP. When I go into Norton it is telling me the dreambox is offline. It also tells me I have several other devices all offline that are sharing the same IP address 192.168.1.102 | ||
| connection, dcc, problem |
