How to view card info on Dreambox
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 02-10-2009   #1
My System: 1M Motorised Dish, DM 500s, Digital+, Sky+, TDT
What menu do I enter to see viewing card/subscription information on a Dream 500s because I cant find it.
Thx
redout is offline   Reply With Quote
Old 02-10-2009   #2
Archived Member
Thx
I use the PC to view card info.
Use browser like IE, type URL
_http://yourboxIP:16001
Select CCcam with the receiver blue button.
On the browser you should see info about the cards in the card slots.
Choose Entitlements menu.
HB13DISH is offline   Reply With Quote
Old 02-10-2009   #3
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
There is also a plugin called CCcam Info that runs on a Dreambox:
Plugin para gemini+cccam
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is online now   Reply With Quote
Old 03-10-2009   #4
shumifan50's Avatar
My System: 2xDM7025(DVB-S tuner), DM600SPVR, DM800S, TM9100, Triax 90cm with MultiBracket 4 sats.
If you are using the white card with newcs you will have to go to http://<dreamboxip>:8080 to get the info from newcs as CCcam will not show it. If you adjusted the httpd port in newcs.xml then you have to use the adjusted port. Same really applies for CCcam.
shumifan50 is offline   Reply With Quote
card, dreambox, info, view
