Gemini 4.4: /usr/script/E2_LOADEPG_userscript.sh incorrect | | /usr/script/E2_LOADEPG_userscript.sh inserts a new line to move
/media/<device>/ext.epg.dat
to
/media/<device>/gemini.epg.dat
every time it runs.
This means that the file ends up getting copied many times if you run this script from the blue panel.
To fix the problem edit the script file, after running it once, and remove the line "sed ....." from the script - it occurs in three places for the three psossible devices types (cf, usb and hdd).
This should be fixed in the Gemini distribution. |
