Originally Posted by satter Im happy to say that it works. The message on the SD box never changed, 'cal .......to get HD'. So i thought i didn't get the update. But then i tried it in my sky hd box and sky one HD opened and a few others. Not the movie hd channels, got this is the wrong card for this box.
Then tried it in newcs and it is working on all hd channels. |
Hi just to clarify. This is a new
Sky White card that was paired to an SD box. you upgraded the card to HD. The update was sent and the card works as normal in the SD Box (
Sky) and you say you checked the HD channels on a
SkyHd box also. So the card is pairerd to 2
Sky boxes.
I didnt think it was possible with the new white cards. I had my old HD card paired to a
Sky+box along with the original card for that box but I could not get a new White card to activate and so bought a
Sky HD receiver off Fleabay just so I could get it updated for use in my DM800
On further reading your HD box is not paired to the card or all the channels would open.
My interest is because now that I have an HD sky box I was thinking of upgrading the
Sky+ account to Hd without buying another HDbox. But I was thinking if I did this what would happen to the original card that is in my 800? It still needs to go into my
SkyHD box to get the updates(Well Newcs/MGcam can update it now),
Anyone think I can have 2 white cards paired to 1 box. It was possible with Blues .
