Using more then one card in NewCS. How? | | Hi,
I have been looking all over to find the solution but can't find it.
I have a lot of cards and want to use them all in NewCS on my linux pc cardserver (ubuntu 9.04) I have:
Sly
Canal Digital NO (conax)
TVVLAANDEREN (seca3)
VIASAT SE
Canal Digitaal NL (seca3)
I understand i just have to add devices, but do not know the settings for all these cards. The sly card is working perfectly.
The seca cards i found out that parity needs to be even not odd. But the seca cards crash newcs all the time. After 5 minutes it crashes. And never got them to clear the channels. The viasat card does not crash NewCS but i only get BD ecm from it, the card is working in the official box.
In the webinterface i can see entitlements and keys for all the cards. The only card that clears channels on the dm is my sly card.
What should i do?? I use smargo card readers. I have one omnikey reader, but haven't used it.
Or should i just install cccam on the server also and connect newcs to that and have the other cards in cccam?
If someone could give me xml for those cards that would be great.
Right now i have seperate bins and xml's for each card.
Thnx |
