Weak Signal with my DM
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 17-10-2009   #1
My System: I have only a PC and good internet connection.
I have a serious problem with my Dreambox, it is weak signal on Eutelsat 7 degrees then Digiturk.
On SNR, it is 85% and BER is 0
SNR 85%, the maximum signal control I can get.
But the picture freezes and then the image running again after 0.5-1 min. and so keep it on so continuously.
(The signal is just as same when the picture freezes)
How can I fix this problem? or what is the problem?
heye is offline   Reply With Quote
Old 17-10-2009   #2
Amo Amas Amant Admin
Topper's Avatar
Well
There is simply too little information for people to help. What subscription do you have, if not a subscription how are you clearing the channels, is it c/s.....who set this up? what cam/emu are you running?
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 17-10-2009   #3
what kind of information do you wanna know? I have a cardsharing, also connected to a server outside and there are a PC store here in Sweden who offer this and I have contact them they said the satellite is from far away and I wonder how the satellite can be long becuase Digiturk sends to Europe _http://www.lyngsat-maps.com/maps/ew3a_eurb.html
There is running ccam 2.1.1
Old 17-10-2009   #4
Robbo's Avatar
Real name: Mark
Check a FTA channel on one of the same transponders as one of the problem channels. If the picture is stable, then the problem is not weak signal. Besides, a BER of zero, is perfect signal.
If the FTA channel is OK, then its a card sharing issue, can't help on that one.
Old 17-10-2009   #5
smiffie's Avatar
My System: Dreambox 800 HD 500Gb, Dreambox 500 S, VBox 2, Jaeger 99G H to H 36v, Invacom Twin LNB 0.3db, 85 cm Mesh Dish
As Robbo says with 85% SNR and 0 BER it isn't a signal problem.
I'm watching ITV partner on 16E with with 65% SNR and 0-100 BER with no picture problems, but it is with an official local card. Sounds like a CS problem, check the ecm time, anything more than 0.5 seconds can cause a problem.
smiffie is offline   Reply With Quote
Old 17-10-2009   #6
Topper's Avatar
Yes
Well now that we have established it is card sharing, information which you did not disclose in your first post, you simply have too many hops to when you receive the key change hence the freezing, complain to your card sharing ring we cannot help you
Show Your Support
Thank you.
Old 18-10-2009   #7
I guess FTA channels means "free channels" as are available on Digiturk, like whole TRT channels and SkyTürk works perfect and picture is stable but when I change to the other card channel then the picture freezing.
So there is nothing wrong with my DM? or is it the fault of their server who drops page and then freezes the picture by me?
Old 18-10-2009   #8
Topper's Avatar
Well
What could be wrong with your DM? If it's operation is satisfactory on free to air channels then it can only be the C/S causing the problem. These C/S rings tend to be greedy and put too many clients on one server which causes you a delay or they introduce too many hops. They do not care you are hardly going to take them to court are you?
Show Your Support
Thank you.
Old 18-10-2009   #9
ehh What?
Last night I watched and the picture dosen't froze, clock was between 2-3 am. Does that mean it's wrong with their server and becomes congested during the day?
Old 18-10-2009   #10
Topper's Avatar
Well
ehh What?
How can anyone know? the more variables in place the more chance things will not work properly
Show Your Support
Thank you.
signal, weak
