PC CCcam server Wont read N lines. Help!!
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 19-10-2009   #1
My System: i have a dreambox 500c and 1m motorised dish
I have just constructed a clarkconnect PC server running CCcam. All is working well. However when i put an N line from a peer it wont be read. Its not even showing that there is an N line inside Cccam.cfg
Where do i put N lines in PC servers? i dont have a card reader installed. I read my cards with a dreambox using Newcs.
I really need this Pc to read N lines from the dreambox.
Please help
piptaps is offline   Reply With Quote
Old 19-10-2009   #2
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
Hi welcome to the forum. Your problem here is most likely that you failed to stipulate where CCcam read the config file from when you started it.
You need to investigate the available switches when you start CCcam from the command line.
For example I think it is -C to stipulate the location of your CCcam.cfg.
There are 10 types of people in the world. Those who understand binary and those that don't.
Check Out My Blog :- Dreambox Utils For Windows
Best Regards, Your Friendly Dreambox Gimp.
B16MCC
B16MCC is online now   Reply With Quote
Old 20-10-2009   #3
Thank you B16MCC. Im very new to all this. May you give me the command lines to put. C lines are working ok. But N lines wont be read
Old 20-10-2009   #4
B16MCC's Avatar
If C lines are working then you have a problem in the actual N line or it does not match the newcs.xml user details.
If this is your own NewCS server then check the user details via the web interface or in the /var/tuxbox/config/newcs.xml file. Make sure the user entry matches your N line.
B16MCC
cccam, lines, read, server
