Dreambox DynDns ProblemDreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Member Join Date: 28-07-2008 Location: Malta
My System: Dreambox 600 Pvr Dreambox 800 HD Sky Italia Local Card |
Hi Guys I have a small server for my dreambox and yesterday I had to reset router. After setting all Ports and inadyn, I came across this problem. The server is running well and connects to my peers, and when I put in IPofDreambox:16001, CCcam Info page opens well, however when I insert my Dreambox Dyndns in the browser, it takes me to my router and not to the Dreambox Web Control!! Any Ideas on this please Thanks | ||
| 1m Motorized Dish DM600 DM800HD Sky Italia Full Sony Bravia Full HD 40" | |||
| Specialist Contributor Join Date: 07-05-2008 Location: NW, Ireland
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | If you want to access the web interface remotely, you need to open port 80 on your route and forwarrd connections to it to your dreamboxs IP address. Make sure you change the default password on your dreambox. Also, bare in mind that you are taking a bit of a risk opening port 80. The best way to test that it will work from outside your network is to connect via a proxy server. Hidemyass.com would do. This will avoid any of the effects of connecting to your box using a dynamic DNS address inside your own LAN. | ||
| dreambox, dyndns, problem |
