D 8000: problems storing sat positions
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 3 Weeks Ago   #1
Dreaming Satellites
My System: Dreambox 8000 HD, 80cm Orbital Satellite Dish Motorized LNB with 2 outputs, 2nd output leading to upstairs and using Dreambox 500S. Pioneer VSX-1018AH-K Amp/Receiver,
I have just installed Nabilosat Black Hole v0.12 on my Dreambox 8000 and I am having problems storing the sat positions, when I think I have stored a position, when I select a satellite/channel, the dish moves slightly further then the stored position and I get tuner failed, so have to manually move it using the move east/move west buttons,
I also have a fixed s*y minidish connected to tuner B so I get 28.2e (s*y) through that but if I want to view other sats I have to keep going into the tuner setup, which is annoying for me but if that has to be the case, I don't mind but as for other people in the house, they don't want to keep going into all the menus that they don't no nothing about...
Any help will be great..
Thanks,
also, what is the best site to look up exact location/co-ordinates for where I am??
marcaaron20 is offline   Reply With Quote
Old 3 Weeks Ago   #2
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
Why are you storing sat positions ? You should use usals. Use google earth to get your lat and long and then set the tuner to Simple, Disecq Motor and enter the values, job done. If it doesn't line up your mount is off .
There are 10 types of people in the world. Those who understand binary and those that don't.
Check Out My Blog :- Dreambox Utils For Windows
Best Regards, Your Friendly Dreambox Gimp.
B16MCC
B16MCC is offline   Reply With Quote
Old 3 Weeks Ago   #3
satellite lover
Max2000's Avatar
Real name: Max
My System: DM800 with Smargo and Sky UK World+HD option - Toroidal dish with 8 lnb ( 28.2E, 19.2E, 16E, 13E, 9E, 4.8E, 0.8W, 4W) + DM7020s + SkyUK freesat and 120m movable dish with stab rotor and invacom lnb.
Are you really sure, is it a dm 8000 problem? I've seen from "my sistem" configuration, you've a dm500s too. You could check with it of course, if it does the same.
In my old experience, it doesn't seem to be a dm 8000 problem, but anything about the motor or the own dish.
If you fault with dm500s too, I suggest to you to check again every single part of your system (wire, dish, motor, bracket...).
Max
Max2000 is offline   Reply With Quote
Old 3 Weeks Ago   #4
Dreaming Satellites
if it is to do with the mount, i can't understand it cos it was installed by a professional installer who has had many years experience (if i can remember, i think i paid a good £200, at the time i was using a technomate receiver)
Old 3 Weeks Ago   #5
B16MCC's Avatar
It can still move in the wind !
Are you using a simple config with lat and long entered ?
B16MCC
Old 3 Weeks Ago   #6
satellite lover
Max2000's Avatar
Real name: Max
How much time ago has it been installed? Hasn't it its warranty yet?
You may need to ask to your professional installer for a settlement check up.
Max
Old 3 Weeks Ago   #7
Dreaming Satellites
i think it was bout 3 yrs ago when i got the dish and motor installed, nothing more then 3ys ago I am sure of that
Old 3 Weeks Ago   #8
My System: Dreambox 8000 HD PVR, 80cm Dish, 1.2 Compatible Motor, Quad LNB, Porty TV, Yamaha RX-V765 Amplifier, Tannoy Mercury FC Centre Speaker, 2 x Tannoy F1 Custom Speakers, 2 x Tannoy FR Custom Speakers, EPOS ELS Sub Woofer
yeah mate i had similar problem. I just typed in some values until i got it to lock on with all the east sats. I had a few probs because the signal on say 1west might have been 85% and signal on astra2 might have been 60%, obviously i'm after astra2 signal more than i am 1 west and so i fiddled with longitude and now i get 74-75% on astra2 (highest i can seem to get) and 80% on 1west, so all the sats in between seem to lock on nicely.
Google earth told me 001.425 west but i use 000.100east on longitude and it's fine.
Some strange motor results for you all there. Obviously it looks like my motor is not alligned right but if it locks on then who's to be too bothered.
Sharkadder is offline   Reply With Quote
8000, positions, problems, sat, storing
