A few questions before flashing db500s
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 3 Weeks Ago   #1
My System: Dreambox 600pvr Andrews 1.2m Dish 12 inch Actuator V-Box 50 Inch Sony Lcd TV
can somneone answer these questions regarding flashing a db500 over network.
1. When I am flashing via dreamup lan/flash wizard pro do I only need to connect an ethernet cable between box and router? or is there any other connections needed?
2. how do I find out the ip of my router/pc and box?
3. is it possible to download keys via any add ons in the control panel if im connected to the internet?
Im a little confused
regards
hibees04 is offline   Reply With Quote
Old 3 Weeks Ago   #2
satellite lover
Max2000's Avatar
Real name: Max
My System: DM800 with Smargo and Sky UK World+HD option - Toroidal dish with 8 lnb ( 28.2E, 19.2E, 16E, 13E, 9E, 4.8E, 0.8W, 4W) + DM7020s + SkyUK freesat and 120m movable dish with stab rotor and invacom lnb.
Yep, you only need to connect your dream to the router by an ethernet cable.
To have your router ip, you can use "ipconfig" windows command on a telnet session. You'll be able to find your router ip after the command answer, at voice: gateway.
After, you'll have your router and dream ready connected and you'll know much better as your linux receiver works, maybe you could ask again for this answer
Regards,
Max
Max2000 is offline   Reply With Quote
db500s, flashing, questions
