Streaming from dreamboxDreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Regular Member Join Date: 27-08-2009 Location: Staffordshire
My System: Penta 85cm, Quad LND, DM8000,Nabilosat Blackhole v11. |
I would like to stream my dreambox to the internet so i can get it on my iphone, but i want it to stream from the card sharing server, it is running linux ubuntu and is on 24/7 so would be ideal. How do i do it from a putty as i dont know too much about linux. Is it possible to have the stream from the current channel that is on, so when i log into the web interface and change channel it changes the stream at the same time? | ||
| Specialist Contributor Join Date: 13-06-2005 Location: Teesside (North East England)
My System: Dreambox 8000 HD PVR, 80cm Dish, 1.2 Compatible Motor, Quad LNB, Porty TV, Yamaha RX-V765 Amplifier, Tannoy Mercury FC Centre Speaker, 2 x Tannoy F1 Custom Speakers, 2 x Tannoy FR Custom Speakers, EPOS ELS Sub Woofer | the current channel that is streamed will be on, since you are just wanting to stream the source to what is being shown then you will get whatever the channel is on. You then change channel via the remote on the web interface, similar to how slingboxes work. To do it i was told you use VLC, you get VLC to stream from box to pc, then you allow your iphone to log into your external ip address and watch the video from a specific port on the pc. There's loads of examples out there but i don't have a decent enough mobile to try it out on. Basically it's box->pc with vlc on pc, then port forward the streaming port to pc and connect via iphone witha media player installed. You might be able to do it direct from box now but hey that is the way i've always known. Search the 500-s forum, everybody used to ask this question. | ||
My System: Dreambox 8000 HD PVR, 80cm Dish, 1.2 Compatible Motor, Quad LNB, Porty TV, Yamaha RX-V765 Amplifier, Tannoy Mercury FC Centre Speaker, 2 x Tannoy F1 Custom Speakers, 2 x Tannoy FR Custom Speakers, EPOS ELS Sub Woofer | ah, not tried linux but would be a good adventure for you. I may look into it in a few weeks, me and a mate are thinking of using an old pc as a server with ubuntu on to try it. If i get any findings before you then i'll let you know. Not sure i'll be using putty though. | ||
| | #7 | ||
| Dreambox Gimp & Coder Join Date: 16-11-2005 Location: /var/tuxbox/config
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | I doubt you can do it using putty. From what you explain, its no different in linux , windows or OSX as VLC exists for all 3 platforms. Simply run VLC on your linux box and stream as normal. My tutorial will be 99% applicable. | ||
| There are 10 types of people in the world. Those who understand binary and those that don't. ----------------------------------------------- Check Out My Blog :- Dreambox Utils For Windows ![]() Best Regards, Your Friendly Dreambox Gimp. B16MCC ----------------------------------------------- | |||
| | #8 | ||
My System: Penta 85cm, Quad LND, DM8000,Nabilosat Blackhole v11. | It needs to be automated when i boot the machine up like newcs and cccam, as i have the server in the garage tucked away in a corner with nothing connected to it other than the wifi and the card reader. I will have a look into remote desktop and see if i can do it that way. | ||
| | #9 | ||
Blog Entries: 13 My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC -------- ![]() Creator of the CCCCC - only a true wizard could come up with such a name!! | yes I think thats your best bet mate. | ||
| | #10 | ||
My System: Penta 85cm, Quad LND, DM8000,Nabilosat Blackhole v11. | been searching around the net and found a post on this site about it, Streaming Dreambox over the net? will look into it further and try and make it work. | ||
| | #11 | |||
| Specialist Contributor Join Date: 07-05-2008 Location: NW, Ireland
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters |
Installing VNCServer on the PC in the garage will allow you to access its desktop GUI on any PC/Laptop on your network using a VNC viewer . On the Ubuntu machine in your garage, type... Code: sudo apt-get install vnc4server (For some reason, I've had more success with vnc4server than vncserver) Once you've started vnc4server, you can access the desktop on your garage PC using TightVNC. TightVNC can be downloaded here. _http://www.tightvnc.com/download.php | |||
| | #13 | ||
| Regular Member Join Date: 07-09-2007 Location: Europe
My System: 2xDM7025(DVB-S tuner), DM600SPVR, DM800S, TM9100, Triax 90cm with MultiBracket 4 sats. | Complete guide and software for doing it: _http://theyosh.nl/projects/dreambox-restream/setting-it-all-up | ||
| dreambox, streaming |
