NewCS HelpDreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Member Join Date: 24-08-2008 Location: Hertfordshire
My System: 1meter dish & DM600 |
Hi peeps I've read the rules on this topic so I am going to make my post as vague as possible. ![]() I understand that through the NewCS Management Console I can add clients which are saved into the NewCS.xml file. If a receive an N-line in return, would I save this to NewCS.xml or does it go into my CCcam.cfg file. I'm trying to be vague as possible as I got told off last time. I hope I haven't broken any rules. Thanks in advance. | ||
| Regular Member Join Date: 16-06-2009 Location: London
My System: DM800 Panasonic 42" Plasma 1080p Pioneer VSX-LX70 Amp Sky HD B & W 5.1 Speaker Setup Popcornhour Media center Xbox 360 | yes use the newcs web interface to add users. then create an n line incorporating the user and pass you created in newcs. then give this n line to your client (or yourself) to put in cccam.cfg but be warned n lines can be a bit dodgy to give out to people you dont know or trust | ||
| satellite lover Real name: Max Join Date: 21-06-2005 Location: Shetland Islands
My System: DM800 with Smargo and Sky UK World+HD option - Toroidal dish with 8 lnb ( 28.2E, 19.2E, 16E, 13E, 9E, 4.8E, 0.8W, 4W) + DM7020s + SkyUK freesat and 120m movable dish with stab rotor and invacom lnb. | Newcs is something useful to read a smartcard; but it can't work without another emu (as CCcam, Mgcam, Evocamd...). In newcs.xml you may create several users, but each one of these willl have to create a call to the newcs on its real emu to access to the card . CCcam emu uses for this N line. So, every N line should be fixed into your CCcam. Max | ||
| | #4 | |||
Thanks for your help. | |||
| | #5 | |||
| Member Join Date: 23-02-2007 Location: england
My System: i have a 7025 dreambox |
| | #6 | |||
Thanks | |||
| | #8 | |||
My System: DM800 Panasonic 42" Plasma 1080p Pioneer VSX-LX70 Amp Sky HD B & W 5.1 Speaker Setup Popcornhour Media center Xbox 360 | They will then be recieving at hops2 but it shouldnt really make any difference. | |||
| | #9 | ||
My System: 1meter dish & DM600 | In the CCcam config would I still leave the server listen port 12000 as it is or do I change it to the same port as NewCS ? I hope I make sense ? Thanks | ||
| | #10 | ||
My System: DM800 Panasonic 42" Plasma 1080p Pioneer VSX-LX70 Amp Sky HD B & W 5.1 Speaker Setup Popcornhour Media center Xbox 360 | leave it on a different port to the newcs port but be sure to forward the cccam port to the ip address of your dreambox otherwise no one in the outside world will be able to connect to you | ||
| The Following User Says Thank You to andel For This Useful Post: | 215liverpool (3 Weeks Ago) |
| newcs |
