Originally Posted by marcaaron20 These are my current settings on my Dreambox 8000 and using Nabilosat BlackHole V0.12, (just thought I'd write them down before I make changes); |
You can make as many changes as you like. Before you do so, just make sure to create a backup with the Software Manager. It will allow you to backup all your Enigma2 custom settings, as well as you channels list, timers, network config. You can also backup additional files, user defined.
Originally Posted by marcaaron20 These are my current settings on my Dreambox 8000 and using Nabilosat BlackHole V0.12, (just thought I'd write them down before I make changes); A/V SETTINGS:
Video Output: DVI
Mode: 1080i |
I suggest you do different tests, as TV may offer different performance.
I would also NOT suggest to use 1080i as default with the AutoResolution not in use. This means that ALL your channels, including SD channels will be upscaled to 1080i, with poor result.
If you wish to enjoy both SD and HD channels, you MUST setup the AutoResolution features to enable 1080i only on HD channels.
